Lcd panasonic tqfb533
The projector powers down while watching the screens without warning.
Marrie
  • 563 Answers
SOURCE: My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
Posted on Apr 15, 2008
Marrie
  • 563 Answers
SOURCE: Panny AE 700 Shut down
Done
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
SOURCE: No power indications
Remove the six screws from the bottom and 2 screws in the back that hold on the top cover. Once you have the top cover removed you will see a small round red button on the front of the unit. Press this button in; it should not pop back out. Put cover back on and plug it in.
Posted on Dec 06, 2008
  • 144 Answers
SOURCE: Panasonic PT-AX200E LCD Projector - green screen
lcd has gone ajust it
Posted on Jan 31, 2010
How can I flip the screen without the remote control?
Does this projector have a small button on the back for menu? If so then you can access the menu using this. I believe it is under Option 2 and then will be ceiling on or off
Jan 12, 2016 | Panasonic PT LB50U XGA 1024 x 768 LCD...
Hi, I have a Panasonic PT-Ae900e Lcd projector,the lamp has now expired, the unit just shut down. Reading the manual it requires a reset of lamp runtime hours,as it shutdown itself we missed the corridor...
Check for lamp if it's properly installed. You must have screen on yor tv in order to reset lamp time(make sense ?) or your lamp is ok but ballast is burnt?
Hope this will help You
Aug 15, 2011 | Office Equipment & Supplies
My data projector eiki LC-Xb23 goes off without warning and the warning light is flashing
If the power light & warning light both flash red, this indicates that the projector is overheating. Once the projector has cooled down the warning light would continue to flash red and the power light would be solid red.
You should clean the air filters.
The filters are located on the underside. Disconnect all cables and invert. remove the 2 air filters located at the front and rear by pullingthe latches. They are both rectangular in shape.
Being very careful not to damage them, you should rinse the dust out and leave them to dry fully before replacing them in the projector.
This should cure the problem.
Feb 17, 2011 | Eiki LC-XB23 XGA LCD Projector Multimedia...
My panasonic PTLB60NTE shuts down after couple of minutes when I use wireless mode. How can I solve this?
There is three indicators lights on the panel
1. lamp indicator.
2. temperature indicator.
3. computer input indicator.
If your projector shutdown itself without given any indication its mean that your projector function POWER OFF TIMER is on. You can off this function.
How: (two keys back side of projector one is menu second is a joystick witch have 4 arrow keys and center press is enter)
press MENU button to display the menu screen and then use joystick UP or DOWN to select the OPTION menu. press joystick to ENTER and then use joystick UP or DOWN to select POWER OFF TIMER use joystick RIGHT or LEFT to select DISABLE then press MENU two times to exit the menu.
If your projector shutdown itself with given any indication then
If LAMP INDICATOR flashing RED then lamp circuit failure its need to be repair or replace.
If TEMP INDICATOR flashing RED then the temperature inside and /or outside the projector is abnormally high.
CAUSE: The ventilation opening are covered. The room temperature is too high. The projector is located at high elevations (above 1400m)
REMEDY:clean the air filter. Remove the object from the ventilation openings or clear around the projector. Set the HIGHLAND option to ON
Jan 04, 2011 | Panasonic PT-LB60NTE LCD Projector
Menu screen won't come up on screen
The "CONTROL KEY" may be set to "OFF".
In order to set the "CONTROL KEY" to "ON" without using the remote control unit, keep holding
down the ENTER button on the projector and press the MENU button for more than 2 seconds
Mar 27, 2009 | Panasonic PT-LB30U Multimedia Projector
May 25, 2008 | Panasonic PT-F100NTU LCD Projector
HI there
Apr 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
51 people viewed this question
jasbo
jasbo
