Question about Spin Spa The Spinning Spa Brush As Seen On Tv
How to change the batteries in my spin spa - Spin Spa The Spinning Spa Brush As Seen On Tv
Spin spa, I can't get the cover off for the batteries.
try tapping the lid with a screwdriver handle( lightly) repeat.. and take your time slow and steady wins the race.
Jun 30, 2017 | Pool & Spa
The pump was shut down to change the filter. Now it will not restart. I took the pump apart and it will spin IF I give it a manual spin with my fingers. No visible clogs???
sounds like it might be the start capacitor. have it changed at your local motor shop as the stored energy in the capacitor is enough to stop your heart
Aug 15, 2015 | Pool & Spa
My electic starter on my 2000 550 super sport spins when I turn the key but never engages to turn motor over.
week battery or broken or frozen starter bendix Google Search ,it can be oiled, use a lightweight oil to lubricate the shaft , remove the starter an inspect it
Jan 07, 2015 | Pool & Spa
Clocks resets
if you have a 4 button spa remote disconnect if it goes away replace remote
Jul 07, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Phantom does not move gets stuck in one spot
Is the cleaner getting stuck at steps, corners, etc? If so, your spin out is too short. Change the cam to the "winter" position to increase the pool cleaners spin out.
Aug 22, 2010 | Hayward Phantom Pool Cleaner Complete with...
I was putting in dry wsll screws when the drill stopped rotating... The drill will rotate if there is not resistant but as sooon as a little resistance is applied the drill does not spin. I have changed...
Check the brushes. If they are not worn, then you may ahve a bad armature or field in the drill. This happens after contiual use under extreme load or prolonged run times.
Jan 15, 2010 | Pool & Spa
Great Lakes Spa pump. Any way to diagnose outside
If I understand your question, your spa pump will not spin up.
I believe your start capacitor has failed. Remove the back from the motor, you will see the black capacitor on the left hand side. There are several wires coming out of the capacitor. Somewhere on the body is a number. Get a preplacement from a FixYa.com advertiser, your community pool supply company or at www.repairclinic.com
Be careful as you service this electric storage device. Also, make sure you wire the new one exactly like the old one.
I believe this minor service operation will get your pump rolling again.
Thank you for posting at FixYa.com
Please vote
a
Nov 10, 2009 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Spin Spa The Spinning Spa Brush As Seen On Tv Logo
276 people viewed this question
Top Spin Spa Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Spin Spa Health and Beauty Expert? Answer questions, earn points and help others
