Size capacity lsn1000hq0 - Washing Machines
My kodak easy share was not support another sdbcards
SD Cards are of different types size and capacities.
Avoid higher capacities and faster speed for older devices.
You will need to match for a compatible type.
How to Buy an SD Card Speed Classes Sizes and Capacities Explained
Jul 16, 2016 | Kodak Cameras
What size of sd card
Hi
Not sure by size, you mran phyical size or capacity. There are 2 phyical sizes.1) Standard SD card.2) Mirco SD card (usually used in phones) Check what size slot it is. I unsure take device to a retailer to check. If you mean data capacity size? These days most standard devices take from 32Mb upwards, check user manual or google device model specifications. The Extreme SD cards are a higher capacity. Check them out at a camera or retail store. Hope this helps. Regards Bob from OZ.
Jul 23, 2014 | tmax White 8GB 9" Android 4.2 1.6 GHz,...
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
I have carrier heat and air model numbers 58sx and 38tg what sizes are these
You need more information to get the size. The Carrier 58sx series includes 5 different models: 40 - 41000 BTUH, 60 - 61000 BTUH, 80 - 81000BTUH, 100 - 102000 BTUH, 120 - 122000BTUH. An installation guide for the 58sx is available here: http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/58sx-14si.pdf . The Carrier 38tg has 6 different sizes (020 - 20,000BTUH through 050 - 50,000BTUH). The other sizes are 025, 030, 035, 040 and the capacity is that number multiplied by 1000.)
To determine your model's capacity, look at the full product number. The first three numbers after the 58sx or 38tg will indicate the nominal capacity.
I hope this helps.
Oct 25, 2011 | Heating & Cooling
Opening programs is so slow virtual memory running low
which operating system you are using and what is the ram capacity? and onemore thing to check what is your virtual memory capacity. for that
Right click "mycomputer" > properties > advanced >click settings on performance > in advanced tab > increase virtual memory file size.
generally its size is ram capacity * 2 (ex: for 512mb its virtual memory size is 1GB) check that and we can increase the file size also.
Jun 23, 2010 | Compaq Presario 5000 PC Desktop
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Trying to figure out the size of a hard drive
Hi MacLean, and welcome to FixYa,
There is the BIOS way and there is the Windows way:
The BIOS way:
When your computer is booting up, you can interrupt the startup by pressing either esc., F1, Del., F10, or maybe some other key, depending on your pc.
In the setup, you’ll se the disks on your computer, and the size, this size is the factory size, - Bill Gates take a bite and throw it away :-)
The Windows Way:
Rightc click "this computer" choose administer, choose disk handling, here you see the same disks, but now a bit smaller.
This size is you actual space.
regards
/Teis -> Vote, Please
Dec 06, 2008 | Computers & Internet
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
