Question about Samsung SGH-D900 Cellular Phone
Keypad tones - D900i
I bought a new Samsung D900i today. I can not turn the keypad tones off. The function is visible but greyed out. Any suggestions?
  • 2 more comments
  • Marjan Nov 11, 2007
    I bought also a D900i samsung but i couldn't turn off the key pad tone.
  • Anonymous Nov 13, 2007
    i have the same problem. the keypad sound option is greyed out and if i lower the volume at the left hand side i cant hear when i receive a message, also the message tone is crappy because too short and soft how about something else????
    regards
    christelle
  • trishuh Jan 03, 2008
    Umm.. I also bought this phone Samsung D900i..
    But when i start to text I hate the dot dot dot sound.. :(
    can't i just turn that sound off because i love the normal keypad tone when you browse.. :)
    please help.. thanks!
  • Anonymous Mar 22, 2014
    New cb(200) cannot get the keypad sound turned off
Change the dialing font style to Normal and then set off keypad tones on setting menu.
Posted on Jul 11, 2008
TONTO!!!! BOBO!!! TANGA!!! INUTIL!!!! just press the silver side of your fone to turn off keypad tone
Posted on Jan 07, 2008
    Problem Solver:
  • 5 Answers
I too used the silver volume key on the left to reduce volume - once you reach 0, an off option appears.
Posted on Dec 30, 2007
Hahahaha no it works wen you change the drawing pen in number mode...
choose numbers
then save
go back and keypad tones is available to modify without losing text recive or ring volume
shaazaaam
Posted on Jun 15, 2008
Yep you can use the volume keys on the left as well as the other method ...all works fine :)
SuperDuperRahul
Posted on Apr 02, 2008
The silver volume keys on left hand side turn the keypad volume off.
Regards Maggie
Posted on Dec 19, 2007
You have to go onto >> settings >> display settings >> dialling display >> font type >> and change it to normal
(that's where the "scribbly pencil" resides)
Posted on Dec 17, 2007
Keypad tones cant be turned off if your using the scribbly pencil text style. It uses some preset for a bunch of setting and wont let you turn off the keypad tones. It worked for me, I have a gsm
Posted on Dec 09, 2007
Just use the volume key to turn it down to 0
Posted on Nov 25, 2007
Go onto display settings then Tv-Out, and change the setting onto "NTSC". This will then allow you to access the keyad setting to turn the sound off and on again.
Posted on Oct 09, 2007
SOURCE:
How to turn off the keypad tone for my samsung d900i
On the phones sides there are two buttons. Press the lower button severally and the tone reduction will be displayed on the screen. Alternatively, go to settings, then select sound profiles then select normal then option, edit then scroll to keypad tone then mute.
Oct 04, 2011 | Samsung SGH-D900 Cellular Phone
How do i turn the keypad sound of on samsung tocco
Go to settings,
select phone settings,
volume key function,
select silence
then save
Now you can turn the volume of your keys up and down with the button on the side of your phone
JonnieC
Oct 06, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
Can't turn the keypad tone off when i text - samsung tocco f480
You've probably found out by now, but I've been tearing my hair out to solve this and have finally done so today. Menu -> Settings -> Phone profiles. Then select the righthand double arrow icon for the profile you want to change (likely 'Normal' at the top). From the pulldown list at the top right, change 'Incoming...' for 'Phone sounds'. Scroll down to the bottom of the resulting screen (using the lefthand handset buttons if, like me, you have trouble scrolling) and set the 'Phone sound volume' (slider control) to '0'. Then hit 'Save at the bottom, and job done!!! Phew!!!!
Neil J
Jul 05, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung D900i
Well i will check on that for you
Jan 09, 2008 | Samsung SGH-D900 Cellular Phone
Samsung D900i.. Please help meee! :(
Hi and happy new year this should be easy to solve you need to go into settings then profile and then select the profile you use then goto the settings in the profile mode then their should be an option that says keypad tones turn this off then this should solve your problem let me know how you get on ok.
the silent profile should have this turned off anyway but using this profile means you will have no ringtones or anything so you need to alter the settings in the general profile once you change keypad tones you need to then activate that profile again then this should be solved good luck
Jan 03, 2008 | Samsung SGH-D900 Cellular Phone
'Keypad tones' option unavailable
change profile mode to custom sttings may be u are using the factory defalult profile setting
Dec 04, 2007 | Samsung SGH-D900 Cellular Phone
Keypad tone
You need to change the display, change the display so that handwriting is NOT selected and then you can change the keypad tone.
Sep 12, 2007 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
1,903 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
