Question about Logitech Harmony 200 Universal Remote - Simple Setup, Large Buttons, R
My harmony 200 will only change the TV channels . it will not turnit off,ov or perform any other function
3 Suggested Answers
dinomb
  • 16 Answers
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
Posted on May 11, 2008
  • 59 Answers
SOURCE: Harmony 880 Logitech won't change channels
Was it working before?  Is it possible you selected the wrong brand of TV when programming the remote?  Do you use a cable box or satellite dish with your TV (in other words, do you change channels by changing the channel on the TV, or on the digital box connected to your TV)?
Posted on Jun 08, 2009
Can not get the remote to let me change input on my tv for my cable channels to come in it is on AV 1 any suggestions
The Phillips remote is incapable of this function. You need to look into a Logitech Harmony remote. Expensive bur awesome. Get a rechargeable one. they go thru batteries pretty quick
Dec 31, 2010 | Philips Magnavox Learning Universal Remote
Logitech Harmony remote having trouble changing the channel
Harmony remotes use IR commands, so you will always have to have line of sight for it to work.
However, if you are using the RF extender, ensure that the device you are using to change channels is assigned to the extender, and that the extender is properly paired.
Feb 20, 2010 | Logitech Harmony Remote Control
The power flickered on and off last night and since then I cannot get my Harmony 890 remote to change channels. We have Direct TV. It will control the volumn and turn the tv on and off, but will not...
You DirecTV device may have been reset ack to RF. You'll have to make sure the device is set to accept IR commands in order for the Harmony remote to work on it.
This link will help you.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12985
-D
Oct 31, 2009 | Logitech Harmony 890 LCD Remote Control
Logitech harmony xbox 360 remote not communicating with 360.
There is a setting that may need to be changed within the Xbox 360, to allow it to be controlled by a Harmony Advanced Universal Remote.
To configure your Xbox 360 to respond to a Harmony Remote
  1. Using your original Xbox 360 controller, go into the Xbox Dashboard on the Xbox menu
  2. Select "Console Settings"
  3. Select "Remote Control"
  4. If "All channels" is selected, select "Xbox 360 Media Remote”. If "Xbox 360 Media Remote" is selected, then select "All channels"
Your Harmony remote should now control your Xbox 360
Oct 20, 2009 | Logitech Harmony 360 LCD Remote Control
Mar 30, 2009 | Logitech Harmony 880 Universal Remote...
I am trying to set up the "favorite channels" function on my harmony 880 remote and I keep getting an error message that the channel numbers are not valid. On my TV, for example, NBC is 05-1 (that's what I...
I have seen channel designations like this when using a satellite TV provider. From what I know (which is not a lot, I'm afraid) is that some affiliates offer analog and digital and digital sub channels so an example would be:
05 (main analog channel)
05-1 'digital' (depending on the receiver)
05-2 'digital sub channel'
05-3 'digital sub channel'
etc
So, you may want to try just putting in the main channel '05' when using the Logitech software to program your favorites. Below is a link to a good post on the Logitech forum that tells how to program your favorites. Hope this helps!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9691
Mar 24, 2009 | Logitech Harmony 880 Universal Remote...
Harmony 659 won't learn samsung LN-52A850S1F remote
Samsung has recently acknowledged an issue with 8 series LCD TVs (e.g. LN52A860). When the TV is first turned on, it outputs strong IR interference which can render the Harmony unable to control your devices for several minutes. After the TV is warmed up, the interference dissipates and the Harmony will work correctly again.
To determine if your Samsung television is causing the issue:
1. Start an Activity that uses your Samsung TV
Confirm the Harmony is not controlling your devices
2. Completely cover the screen of your television with a blanket or dark colored sheet
3. Try changing the channel. If the device now responds, the television is interfering with your devices. Please contact Samsung for support
It is possible that by disabling certain features on your TV can also resolve the issue. Features that may cause interference with your remote include:
1. DNR/Active Control
2. Power Saving Mode
To disable either of these features, please consult the user manual for your TV.
Mar 04, 2009 | Logitech HARMONY 659 Remote Control
Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
Feb 14, 2009 | Logitech Harmony 880 LCD Remote Control
May 11, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech
You need to be more specific about your problem.  Have you already programmed your Harmony Remote on the internet?  Does it control all other functions (such as changing channels) on your TV?
Do you have any other components connected (such as a Home Theater Receiver) that might be a source of sound?
Please post more details, and I may be able to help.
Jan 20, 2008 | Logitech Harmony 880 LCD Remote Control
Open Questions:
See all Logitech Harmony 200 Universal Remote - Simple Questions
Logitech Harmony 200 Universal Remote - Simple Setup, Large Buttons, R Logo
20 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
