Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
My emerson EWC19T5 turns on 5 or 10 seconds and shuts off
I have a Emerson model LF391EM4 flat screen that when turned ON shut itself off after apx 10 seconds. It has never done this before, what can I try to do?
REBOOT IT BUT HOLDING DOWN ON THE POWER AND TURN IT BACK BUT HOLFD IT DOWN FOR ABOUT TEN SECONDS AND THEN TURN IT BACK ON
Jan 09, 2017 | Emerson Televison & Video
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
We have no remote we need to shut off timer how do we do that on a emerson ewc19t5 tv dvd/vhs combo
look on shop jimmy's website to see if you can get a remote from them.
Oct 05, 2014 | Televison & Video
Can I get l get local channels if my cable is off.
If your TV has a digital tuner built in then yes. If it's an older TV then you'll need an external digital tuner box and an outside antenna.
Sep 08, 2014 | Televison & Video
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
My emerson tv is turning it self off
my tv shuts off after a few seconds what can i do to fix it
Sep 12, 2008 | Emerson EWL20D6 Television
Remote codes
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
thats pdf i got my info off of
May 10, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
22 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
