Question about Horizon Fitness T100 Treadmill
Upper board on Horizon T100 tread mill will not power up
Upper control board will not power up. Lower board has 1 amber LED that lights briefly when lower power switch is turned on
2 Suggested Answers
karlsomers
  • 58 Answers
SOURCE: where can I buy motor control board for horizon treadmill T101
just run in the open air, it's much better to experience real life
Posted on Jan 06, 2015
Stuck in up position. Bought a new incline more and if it goes above 5, it will keep climbing and won't come down.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 24, 2016 | Horizon T61 Treadmill
Hi I have a horizon t4000 premier treadmill, everything seems to work fine when I plug it in, it all the console displays fine, but p1 (programme 1) just keeps flashing and no response from any of the
Hi Anthony, sounds like there is a bad connection from upper to lower, a pinched or bad cable, or bad solder on a connection point.
With the "flickering" of the console lights mentioned, this tells me that the power supply connections to the console were suspect at one time, and doing nothing and having it "work ok now" is not a good sign of something being fixed. Also, with the flickering, this would mean the upper board would be intermittently powering up / down, causing massive trouble with the onboard CPU which is trying to operate the system. I would advise against using the unit the way it is, and have the control board checked. You can contact jatinah electronics for further help if needed. Good Luck!
Jan 11, 2015 | Horizon T4000 Premier Folding Treadmill
Omega 3 treadmill - Does anyone know what might be wrong with my tread mill? its showing 500 on the screen and is not starting.
replace the old batteries (if your system have batteries, clean the contacts batteries) put a new ones.
2) adjust the REED swtich see the diagram attached.
3)tight the ribbon cables inside from display board and clean it. tight and clean the upper and lower connector. and try again.
God bless you64554154-b7bd-4100-8a70-779a1727ba63.gif5b2cf7d6-545e-4e9e-80cd-605d4c8ca29d.gif
Oct 16, 2013 | Horizon Exercise & Fitness
How do I calibrate my horizon t102. I turn it on and the level motor continues to run, the treadmill motor wont come on. I think it is a level sensor that is bad. Where is that located
The "level sensor" is built into the elevation motor assembly, which is a 10kohm potentiometer. What year treadmill? If the elevation motor assy has a small connector with an orange, blue and brown wire set, you can use an ohm meter to read this pot on these leads. It sounds like a loose cable upper to lower, or possibly a faulty motor control bd which controls the elevation. Unplug tread before looking around..
Oct 20, 2010 | Horizon Fitness Horizon T102 Treadmill ...
I have recently moved my Quantum treadmill and now it wont work?! The red power light is on but nothing else?
Please check your cable from upper console to lower control board. Movong treads can pull these loose.
Oct 17, 2010 | Quantum Exercise & Fitness
The treadmill powers up but the belt will not work
the motor controller has failed and will need replaced
Aug 01, 2010 | Horizon Fitness Merit Fitness 725T...
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Dec 19, 2008 | Philips BDS 4611 46 in. Plasma Television
Fr33e motherboard
you should have a plug like this: ::::. Upper 1&2 - Power/sleep LED Lower 1&2 - HDD LED Upper 3&4 - PWR Button Lower 3&4 - Reset
Sep 03, 2007 | FIC FR33E Motherboard
Horizon Fitness T100 Treadmill Logo
42 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
