My HDTV has lately started showing a red mist effect on dark areas of the screen from time to time, it is also showing this redness at the top and bottom of the screen when watching wide screen films, where the bars above and below should be black and when switching channels where the old blackness now has a red look about it, any help would be appreciated. thanks
SOURCE: SONY KLV30HR LCD TV RED EFFECTS
You probably need to replace the backlight. In parts less than 30$. If you know your way around these things, or know someone who does, it's not a super difficult thing to do. You can get a tutorial that's written for monitors here: http://www.inventgeek.com/Projects/shorts/lcdfix.aspx basically the same procedure for an LCD TV. Good luck!
SOURCE: Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
SOURCE: Westinghouse 32in HDTV-Ready
Unfortunally they do not sell replacement parts for westing tv's. They sell the complete module only. Your problem is in the main module. But before i change any parts i would check my antennae or cable connections to make shure everythins is ok in that area
SOURCE: lg 42pc1d plasma tv red sparkles
I had the same problem, LG came out and it turned out to be the board that filters out the interference around the screen. I pretty sure that was it, took them 10 mins to fix by replacing a few of the boards inside the screen. Sorry I can't be more specific but its not an unfixable problem, so nothing to worry about.
SOURCE: RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Hi, I've got the same problem with a digistar 42" plasma. Ever figure it out? I'd appreciate it if you'd email me at [email protected] . Thanks
I have the same problem..only had my tv for 30days. red is every where this tv is going back.
