Question about Air Tools & Compressors
Restarting sullair 185 diesel compressor after running it out of fuel
5 Suggested Answers
ollie reece
  • 1167 Answers
SOURCE: I have a Sullair 185 air compressor. The engine
your not return balve is stuck open or your valves are sticking the pressure from the tank is going back to the pump so when the compressor goes on the compress stroke its very hard as it has to open the valve with pressure behind it its hard to explaing buddy but on the tank you wil see anon return valve from the pump unscrew it and inside is a rubber with a spring turn the rubber around and try this if doesnt work you need to inspect the valves (if sticking) good luck
Posted on Sep 02, 2009
compman66
  • 169 Answers
SOURCE: 1989 Ingersoll Rand 185 diesel compressor shuts down under load
most have safety shut downs built in, on the compressor side you will have a high discharge temp shut down, usually set to shut down @ 230 degrees F. normal temp should be @ 180F if it is running hot first check oil level on the compressor, and that the radiator is clean. some machines will have a thermostat that will only allow oil flow to go to the radiator after it comes up to about 150 degrees F. you really need to have a manual on the machine to see what other safety's it may have on the compressor and engine side as well.
Posted on Jan 09, 2010
Testimonial: "Thank you very much for responding. It was a little low on coolant. The comp. oil level was fine. I changed the fuel filter and the prob is gone"
  • 18 Answers
SOURCE: Sullair 185 screw compressor
The sullair 185 has a low oil pressure override button that you have to hold in while starting. after the oil pressure builds up(takes about ten seconds) you can release the button and the machine should continue to run.
Posted on Jul 10, 2010
  • 1274 Answers
SOURCE: I have a sullair 185 engine dies and light blinks
Hi, my name is John. Welcome to FixYa. Low oil level, and poor air circulation. Thanks for choosing FixYa....John
Posted on Nov 29, 2010
Sullair 185 has oil in air discharge line
The rings of the compressor piston are not sealing.
Dec 08, 2016 | Air Tools & Compressors
Engine starts but cannot speed up
sounds like you have a pressure switch sticking or has failed .
Aug 11, 2015 | Cars & Trucks
Sullair compressor 185 cfm diesel
will need the fuel system bleeding loosen the pipes going to each cylinder, when they are all leaking fuel tighten back up it should start then
Sep 01, 2014 | Cars & Trucks
Fix low volume problem sullair 185 does not produce sufficent air to run large jack hammer
Increase the setting on the regulator (on the compressor) or maybe the compressor lacks the cfm output needed to operate the jack hammer
Dec 17, 2013 | Air Tools & Compressors
Hi. My company has a Sullair 185 diesel air compressor that will run for approx. 4 hours than shut down. The indicator lamps flash "4" flashes and the unit will start right up. We do not have a...
Take note of page 24 in this PDF
http://www.scribd.com/doc/45811151/Manual-de-Mantenimiento-Sullair-185
It states the 4 flashes indicates low engine speed it is part of the SSAM system.
Jul 19, 2011 | Garden
I have a sullair 185 engine dies and light blinks one and says compressor over heating what causes the compressor to overheat
Nov 22, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
Feb 19, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
Air Tools & Compressors Logo
57 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
