Question about Toys
Reset kitac final jugler slot machine - Toys
2 Suggested Answers
SOURCE: Kitac Gogo Juggler locked up
Went online and found a pdf file that had the entire manual. HE meant "hopper empty" so I filled the slots in the hopper and opened and closed the cover. I also determined that I need to eventually change the lock as I had to jiggle it a while to reset.
Posted on Mar 30, 2008
My slot machine will not reset
http://www.ehow.com/how_7614038_reset-slot-machine.html
However, the process may differ from machine to machine. Try Googling information about resetting your specific machine.
Feb 26, 2015 | Computers & Internet
Hello, I have a Xerox 4510 DT that shows the error: RAM ERROR. I have had the users shut down the machine, wait a minute and then restart but the error still shows. What else can I have the user do?
You can try inspecting and moving the ram to the other RAM slot. The 4510 image processor board has 2 ram slots, so one of them should still be unused. To access the ram you must remove the right side cover. Its possible changing the slot the ram is in will fix this, if it does not the next step would be to replace the ram. Part# 133K27760 for 128MB. Finally, if after replacing the RAM the error continues you would need to replace the image processing board. (part# 960K41806). Hope this helps
Aug 01, 2011 | Xerox Phaser 4500 Printer
Kitac juggler slot machine
how do I adjust coin acceptance size?
Oct 24, 2010 | Toys
I cannot replace the coffee grounds container. Something is preventing it from going in properly
Hi
There is a slot on the side of the machine where the grounds box goes. Turn the machine on. Slide something like a plastic knife or credit card in the slot towards the back (front to back), not from the side. The motor should run and the machine will reset itself. Don't take anything out while the motor is running, or this will happen.
If it doesn't reset itself you may have a broken gear drive.
Jan 04, 2010 | Saeco Magic De Luxe Espresso Machine
I have a sheet that is stuck in the bottom of my washer. how can i get it out?
I purchased the Kenmore version of this machine about 7 years ago, and have had nothing but problems. 2 pumps (I finally learned how to clean them out and replace myself) and many agitator problems.
The large, dome on top of the agitator has little slots on the edge about midway. Use a slotted screwdriver (not too long) and wiggle each slot in succession while pulling at the dome. This will reveal several bolts holding down the agitator plate. Use a socket wrench with an extension. Be careful to get all the bolts out before lifting the agitator plate (you may lose them). You cannot remove the plate from the machine in this state, but you can lift it up and free any stuck clothing.
I have heard that they make a kit now to prevent this.
Good luck.
Nov 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I hit jack pot on my slot machine now i cant reset it
The key you use to open the door turn left not right while the machine is on and making noise.
Most new users, get a hopper empty error confused with a jackpot.
add more tokens into the hopper then turn front key left.
If all else fails look for a black or red button on inside of the door or near the MPU board. Hold down the button (not letting go with one hand)Then with other hand turn power off then on.
Count to ten then let go of button.
That will default most machines, but take note the credits will be gone.
Hope this info helps---
Nov 17, 2009 | Mini Super Slot Triple Thunder Slot...
System does not see new video card
Confirm the card works in another system to eliminate it as a suspect. Try a beefier power supply in the machine (sometimes these 300 to 350 watt supplies just cant hang when an addon card is installed). Check the BIOS settings and make sure that the PCI Express slot resources are active for the card. If the card uses a power connector, make sure it is connected. Keep us posted.
Mar 21, 2009 | Gateway GM4019E PC Desktop
Mar 29, 2008 | Video Game Consoles & Games
Washer stuck on Final Spin
Sounds like a bad timer to test this you need a multimeter to check voltage to the advance motor if so equipped.
Oct 09, 2007 | GE WBSE3120B Top Load Washer
Toys Logo
15 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
