Question about Garden
What is the drive belt length for victa 4015hx
How to replace drive belt on victa 38' ride on mower
There are more but they are pretty much the same across the board fitting wise....Hope it gets you on your way!
May 07, 2017 | Garden
I have the right belt so Zanussi tells me, but it seems to be 1 inch short. I have loosened the motor and everything else, but it is too short. The belt has the number 1196 . HELP
You have not specified the model of washing machine and it is impossible to give the correct answer. But I can generally explain the characteristics of the belt. It is elastic drive belt 1196 J5 which means that 1196 mm is the working length based on the belt mounted on the pulleys. "J" and "H" means shape of the drive belt and finally number after word (J5) means number of teeth (could be: 4,5,6,8) .The length marked on the drive belt (1196,1217,1280 etc.) is the working length based on the belt mounted on the pulleys. For a given working length, the belts - which consist of different materials - have a different degree of elasticity. This means that, when not fitted to the appliance, their lengths may be different. It is normal that the length of a plastic belt not fitted to the pulleys is three or four centimeters greater than that of a rubber belt. Also, both types of elastic drive belt are shorter than the working length and therefore it is a little more difficult to replace but not so much that you have to lossen motor.
Please follow this link:
https://www.youtube.com/watch?v=yC21q2-eAfI
Dado
Sep 17, 2015 | Zanussi Washing Machines
Zanussi fls 1284 - how is it possible to make the right belt fit - I have tried and tried - it will not fit. What can I do?
Dado
Sep 13, 2015 | Zanussi Washing Machines
Stanton str8-20 belt size???
HI,
If you are unable to find your turntable measure the nearest length, if you are unable to find the exact length (as belts stretch slightly with use and age) choose the nearest shorter length. To check drive belt length for most type full platter decks remove mat and lift platter off center spindle (remove circlip if fitted), turn platter over and measure the circumference of the drive hub and deduct 5-10mm to determine correct length and tension
OK
Dec 11, 2012 | Audio Players & Recorders
I have a problem with my ride on mower. we need to replace the belt that drives a twin cutting disks on a Victa 4013TX but cannot find any diagrams to help.
4013 HT is a Victa with a 13hp briggs and stratton engine normally with a twin blade 40in deck. These were badge engineered Noma mowers and essentially equivalent to murrays made at the same time. Check diagrams for murray decks to find one with the same deck configuration.
Jan 08, 2011 | Garden
I need to replace my serpateen belt how do i do that?
This label shows the accessory belt routing on a Lumina with a 3.1L engine
  1. Disconnect the negative battery cable.
  2. Remove the drive belt shield.
  3. Fit a 3/8 inch breaker bar or ratchet to the square hole in the tensioner. Lift, or rotate the tensioner off of the drive belt. When the tension on the belt is removed, slide the drive belt from the pulleys.
To install:
  1. Taking care to follow the proper routing of the belt, slip the belt onto the pulleys. As a help, note that the water pump pulley is usually driven from the back (smooth side) of the belt.
  2. Fit a 3/8 -inch breaker bar or ratchet to the square hole in the tensioner. Lift, or rotate the tensioner and, with the belt in place, gently release the tensioner.
  3. Verify that the belt is correctly routed and aligned in the proper grooves of the accessory drive belt pulleys. Inspect the drive belt length scale on the drive belt tensioner for the proper indicated length. If the drive belt length scale does not indicate the proper installed length, the belt may be incorrect, incorrectly installed, worn out or the tensioner may be defective.
  4. Connect the negative battery cable. Start the vehicle and verify correct operation.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 58; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Dec 09, 2010 | 1997 Chevrolet Lumina
I need a belt diagram for a victa ride on 18.5 hxt
Ross , What year is your Victa ? Most HXT models I know of were made by Noma and are effectively similar to murrays of the same era. If you have given up I may be interested in the mower or any 1970's Victa ride ons.
Oct 29, 2010 | Garden
Looking for a victa pro 12 ride on mower parts catalogue
what year? and if you can post a picture it can be more helpful. Victa ride ons were made by other manufacturers with Victa stickers on them.
Oct 02, 2010 | Briggs & Stratton Garden
I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Nov 18, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
