Where does the c wire go on a rheem model rhll-hm3821ja
I just got this ac replaced and they left blue wire at handler disconnected now I'm trying to install a Honeywell wifi thermostat and need to hook that wire correctly,, thank you
  • 49 Answers
SOURCE: Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Posted on Oct 14, 2007
  • 49 Answers
SOURCE: Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
If you have a heat pump do not put your blue wire on b. Put it on x or c. If you don't have an inline fuse you may have blown your transformer.
Posted on Dec 04, 2007
johnsonr1
  • 91 Answers
SOURCE: Need to know wiring diagram for a weathertron
this link has a good diagram of the wiring. It should help you.
http://www.hvacmechanic.com/forums/hvacr/messages/17573.htm
Posted on Nov 05, 2009
  • 415 Answers
SOURCE: Upgrade Baystat 239 to a Honeywell RTH7600D controller
For Trane sytems, B is your "Common" wire. O is your reversing valve relay, G is your fan, Y is your compressor contactor, R is Hot, Brown will not be used on your electronic tstat. X2 is your backup electric heaters. Without knowing what terminals are on your new tstat, I cannot offer more information than this. The installation manual may indicate what each terminal is controlling. I strongly suggest to write down ALL of the terminals and colors from your old t-stat and be sure to turn off the power to your air handler. Put the fan switch on your tstat to ON before turning off the power. Make sure the fan is running. Then turn the power off to your Air Handler. If your fan stops running, you have turned the power off to your tstat and are ready to start replacing it with your new tstat. I hope you find this helpful. Good Luck!!!
Posted on Feb 07, 2010
bobicehouse
  • 1524 Answers
SOURCE: I'm installing a Honeywell RTH6350D
One to R terminal the other to W terminal
Posted on Nov 04, 2010
How do you clean the fan in a rheem air handler?
Pull the blower assembly...2 screws on the angle bracket holding the blower & disconnect the wiring if needed to the motor.
May 28, 2014 | Rheem Complete Split System Straight...
How to fix a secondary drain problem on a rhll-hm6024ja
Hi Ken, Usually an ac repair man will take the front cover off the main AC coil. Inside,Below the you'll see the main drain pan. depending on how the drain is plumbed, the main drain should be to the left or right, corner. If you have a small compressor, you can blow out the line. If not, a electrical snake, or wire coat hanger will suffice. Be patient and go slow. Make sure you put a small hook on the end you'll put in the line. Move forward and backwards every two inches. Assuming you have two lines ( one for primary, one for secondary,) You should have a trap on the line. when you get to that portion take it slow. chances are your cloge is in this area of the line.
May 12, 2014 | Rheem 5 Ton 16 Seer Air Conditioning...
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
Change out problem
AIR HANDLERS DO NOT ENERGIZE REVERSING VALVE , THE THERMOSTAT DOES THE JOB THROUGH THE O  OR B TERM TO THE OUTSIDE UNIT. IF YOU HOOK UP TO O TERM AND HEAT COMES ON WHEN YOU SET AC ON THEN SWITCH TO B TERM ON STAT. YOU SHOULD HAVE O TERM ON CONDENSER OUTSIDE AND YOU USE ORANGE WIRE IF YOU HAVE ONE. IF NOT USE UNUSED WIRE IN 6 WIRE STAT HARNESS.
Apr 21, 2010 | Heating & Cooling
Wiring match-up
If this is a standard heat cool unit. You have a tstat with rygwcob. Just color code the wire to the unit. Some air handlers such as Rheem and carrier use different collors for there common Carrier black Rheem or Rudd Brown. Two wires that go outside use yellow blue. Yellow to Y fron Tsta and blue to common or blue,blavk or brown.or C
May 30, 2009 | Heating & Cooling
Rheem Air Handler will not run. This is a 2006 Rheem model RHLA-HM3617JA Air Handler. I replaced both the condenser and air handler circuit boards. I replaced the motor in the air handler.. The condenser...
Have you hard wired your fan motor to verify that the motor and or the capacitor are good? If you do a continuity test of the motor leads(with electricity off of course) you can see if the motor has open or grounded windings.
Apr 11, 2009 | Ruud Handler Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
