Question about Dishwashers
I need a schematic for Kenmore dishwasher model 665.17722K900
Portable dishwasher hose replacement procedures
aborcass
  • 2651 Answers
SOURCE: KENMORE DISHWASHER
behind either the lower access panel or the behind the main door assy shlould be a tech sheet complete w/ trouble shooter and wire schematic
Posted on Mar 08, 2008
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
Maytag317
  • 1136 Answers
SOURCE: Adapter for Kenmore 17669 portable dishwasher
Hi, Please get me the model # from the label inside the door openong and I will look this up for you.
Vic
garing
  • 998 Answers
SOURCE: Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Posted on Aug 11, 2009
SOURCE: Kenmore ULTRA WASH Portable Dishwasher
i have had my dishwasher for 10 years never a single problem , i connected it turned it on , it filled with water then it just shut down down won;t do a thing. any ideas?
Posted on Sep 12, 2009
Kenmore portable dishwasher leaking on corner and side of bottom right side (facing the dishwasher)Can this be fixed?
Without model # I cannot give you part # but most likely the door gasket needs replacement
Jan 17, 2017 | Kenmore Dishwashers
I have a Kenmore portable dishwasher. The sink connector(not the adapter, but the white connector that has hoses attached) spits water out of the bottom during it's entire cycle. I have used other portable...
I think that the valve assembly in the end of your attachment hose is having problems, check with Kenmore and see if a replacement one is available and if your dishwasher is new enough perhaps it might be under warranty?
May 31, 2014 | Dishwashers
How do i connect a kenmore ultra wash II portable dishwasher to kitchen sink, the attachement on the hose attached to the dishwasher it to big around to fit my facuet
You can get an adapter from a local hardware store. I'd come equipped with make and model number and the screw on screen retainer piece from your faucet.
Aug 21, 2009 | Dishwashers
Can't find an adapter that will fit the hose of my kenmore portable dishwasher model # 17692 (full model # is 66517625692)[
Hi, If you go to www.repairclinic.com they have the part you need. Make sure you enter the model # exactly like this 665.17625692
I hope this helps you. Vic
please feel free to rate me response to you so that others as well as myself can see how I am doing.
Thanks
May 31, 2009 | Kenmore 24 in. 17692 Built-in Dishwasher
Vic
May 28, 2009 | Kenmore 24 in. 17669 Free-standing...
Snap on fitting no longer stays on faucett
go to www.searspartsdirect.com and you can search by your model number for the dishwasher or any other kenmore part. The schematics magnify as you mouse over them and then you can scroll down to see the matching part number. The part 3378117 is the whole hose assembly including the faucet coupler and the full length of the hoses. Notice that the part number 3378117 has been substituted with W10217197. When I Googled for "W10217197 dishwasher" there were a number of vendors selling that part including ApplianceZone.com selling it for $20 less than Sears and other vendors. Unfortunately the way the faucet coupler is crimped onto the hoses you have to replace the full length of hose [not just the coupler] but I have a problem that requires the whole hose. I've opened the cabinet up - which required a star headed driver - and from there it's just a matter of removing basic connectors inside the box.
May 26, 2008 | Kenmore 17459 Free-standing Dishwasher
Kenmore dishwasher various problems
The portable dishwashers of the 70's and 80's often had one area of problem, and that was the pump getting jammed with debris and food.
To eleminate this problem, you will need to open up your dishwasher carefully, and drain all the water and gunk from your dishwashers rinse hose. I recommend taking the machine outside and use a low setting pressure hose (garden hose). With the hose off the rinse side, run the water through and see if it comes out of the pump's housing. Let it run for a few minutes.
The pump also has a switch that also goes with the run cycle. This switch thinks there is not enough water or it thinks it has done its job.
Sometimes replacing the timer helps, but first eliminate the lower hose situation first. If that doesn't help, you will need to then replace timer. If this doesn't help, most likely your pump is most likely jammed or malfunctioning.
May 24, 2008 | Dishwashers
KENMORE DISHWASHER
Mar 08, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
80 people viewed this question
Top Dishwashers Experts
