Question about microsmith HOTLINK XL 6ZONE CAT5 IR
I want to request my puk code number - microsmith HOTLINK XL 6ZONE CAT5 IR
I need puk cod of nokia 5800
If your phone is requesting a PUK code, it is the sim card that is locked and requires the PUK code to unlock it. If you insert another sim in the phone, it will work perfectly fine.
The PUK code means personal unblocking key. It is mostly found on the sim pack, on the sim pack you will see a couple of numbers on the card, there you will see a 8 digit code, that is the puk code.
You can also contact the help center of the sim card you are using for the puk code, they will give it to you.
Take note: puk code request is not for the phone but the sim inserted into the phone.
Hope this helped.
Elect_Comp
Jun 23, 2011 | Nokia 5800 XpressMusic Smartphone
Hi ufone, i forget my puk code please can u give me? my number is 03326644054
A PUK code is issued only by the service provider and then only when requested.
Request another PUK.
Apr 18, 2011 | Computers & Internet
I need puk code etisalat......nessecry
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Oct 20, 2010 | Nokia 6021 Cellular Phone
My phone has this puk on it and i cannot use my phone
Dear Sir\Ma,
The problem of PUK number or code is not simply a phone problem but rather it is a SIM problem. Probably you must have entered a wrong PIN number severally which will now make the phone to request for PUK number or code and it is usually written on the SIM packet but if you can find it, just call the customer care of the network you are using and request for the PUK number, they will be in best position to give you. else you won't be able to use that phone unless you put another SIM card.
Regards
Sep 15, 2010 | LG Cell Phones
I want my puk code of t ata docomo
Dear Sir\Ma,
Regards
Sep 13, 2010 | Lands Phones
Phone is promting for PUK code...what is the PUK
call your service provider or carrier to obtain the pukcode and instructions.
Good bye.
Apr 05, 2010 | Cell Phones
I accidently did the PIN code request setting. I didnt know the PIN so now it says PUK blocked. How can i fix this?
Try clearing pin code 0000 Manufacturer manual inside cover usually has factory settings Call At&t for factory pin setting w/o manual
Aug 07, 2009 | LG Shine KE970 Cellular Phone
How to get back my puk number?
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
Mar 24, 2009 | Teac (DV-W58GA-PUK) Burner
My phone is asking puk number
a PUK number is a security code. if you have entered your pin number in wrong a few times then the PUK locks your phone. Just give your network provider a call and request a PUK number. that should unblock it
Jan 11, 2009 | Samsung SGH-J600 Cellular Phone
PUK CODE
it will ask for the PUK code when you try inserting the wrong pin
for 3 times ...
so to get the PUK code follow these steps:
1. call to your network provider s customer care from some of your friends number of the same network ...
tell your number & ask them for the PUK code..
2. they may ask you the details of sim like in whose name it is etc..
answer that ...
3. after that they will provide you the PUK code note it down
4. enter the noted PUK number to your cell ...
5. your sim will get unlocked ....
caution: if you try inserting the wrong PUK codes for more than 5 or 10 times it will completely block the sim after that you must contact the network provider s shoppe only to get it unlocked ..
remember this ...
this solves your problem ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 13, 2008 | Nokia 1100
microsmith HOTLINK XL 6ZONE CAT5 IR Logo
Top microsmith Home Security Experts
Lawrence Oravetz
Are you a microsmith Home Security Expert? Answer questions, earn points and help others
