My toshiba flatscreen (32C110U1) has a white translucent vertical lines with green horizontal lines. Is this repairable?
SOURCE: vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Posted on Apr 21, 2008
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
  • 100 Answers
SOURCE: Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Posted on Jun 04, 2009
tvservice306
  • 458 Answers
SOURCE: black horizontal line, red parallel vertical lines
REPLACED LCD PANEL
Manufacturer Sharp Part Number RF-R1LK420D3LF2 Description 42" WIDE LCD PNL -
Posted on Sep 28, 2009
  • 7 Answers
SOURCE: White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Posted on Nov 02, 2009
Vertical white lines on half the screen of my Mitsubishi 73835
problem in horizontal circuit, time for a flatscreen
May 11, 2014 | Mitsubishi Televison & Video
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Horizontal white lines 27A43.
    You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
    Jun 12, 2010 | Toshiba 27A43 27" TV
    Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
    My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
    Hiii fairley,
    You aren't specsificly dercribe yor tv set.
    For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
    For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
    Tha's what all I know....
    Hope can help you to solved the problem.
    Thank's
    h3liax
    Jun 22, 2009 | Toshiba 32A33 32" TV
    Vertical line in my toshiba laptop
    I have had the issue before on a regular lcd screen. I had to take it in for repair. If it is still under warranty, you should be covered.
    Dec 05, 2008 | Computers & Internet
    Green translucient vertical bar on left side of screen
    Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
    May 09, 2008 | Toshiba 57H82 57" Rear Projection...
    Toshiba 42h81
    Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
    Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
    Convergence not lining up
    Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
    Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
    Televison & Video Logo
    Top Televison & Video Experts
