My toshiba flatscreen (32C110U1) has a white translucent vertical lines with green horizontal lines. Is this repairable?
  • 275 Answers
SOURCE: toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Posted on Sep 06, 2006
  • 192 Answers
SOURCE: Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Posted on Apr 15, 2007
SOURCE: No Picture Has a bright horizontal line with off white & gray vertical bars
The Problem Philips 27TS54 c101 27B800-7562 White horizontal line in the center of the screen. Color is present in the first half inch of the leftist corner of the horizontal line.
Audio is present and controllable. The green power led from a cold non plugged in state remains solid until CRT goes to ignite. A click is heard then the green power LED blinks.
I found service manual diagram of repair part or parts and install instructions
HTTP://WWW.servicemanuals.net/results.aspx?type=SM&brand=100&model=27ts54
I request any info or tips you might have pertaining to this problem
Thank-you
Sincerely
Gmyers@sbcglobal.net
2/20/2008
P.S. 25”-27” CRT board APT187
Possible Answer Posted by PEE_WEE 4/28/2005
On the CRT circuit board(picture tube), you will find R3340, which is a 10 ohm 1/3w resistor. The location of the resistor is printed on the bottom of the ckt board. It is burned open, replace with a 10 ohm 1/2w resistor. This will solve your problem. The original resistor was sized too small, should have been a 1/2 watt. This resistor is mounted standing up on ends. Mount the replacement resistor the same way. Be careful and don't get the circuit trace too hot and damage the circuit trace. (it's very small) The resistor is located on the crt(cathode ray tube), pcb(printed circuit board) socket. The resistor supplies apx +200v to the collectors of the r, g, b, video driver transistors. If this voltage is low, it causes excess brightness(excess beam current), causing the set to "shut-down". If the shut-down is too quick, you will NOT see the excess brightness, because the picture tube has not warmed-up enough to display anything on the picture tube. To see if the set displays "excess brightness", you will need to turn the set "on" about 5 to 10 times. This will heat the picture tube enough to display "excess brightness", IF that is the PROBLEM. Of course, there are OTHER defects that will cause a tv to shut down. There are built in safety circuits, that will "activate" if excess voltage/current or heat is detected anywhere in the set.
NOTE
My resistors are not numbered the same on my crt board APT187. GSM 02/20/2008
Posted on Feb 21, 2008
SOURCE: vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Posted on Apr 21, 2008
SOURCE: Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Posted on Apr 26, 2008
Vertical white lines on half the screen of my Mitsubishi 73835
problem in horizontal circuit, time for a flatscreen
May 11, 2014 | Mitsubishi Televison & Video
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Horizontal white lines 27A43.
    You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
    Jun 12, 2010 | Toshiba 27A43 27" TV
    White, horizontal line in center with vertical striations.
    55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
    Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
    My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
    Hiii fairley,
    You aren't specsificly dercribe yor tv set.
    For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
    For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
    Tha's what all I know....
    Hope can help you to solved the problem.
    Thank's
    h3liax
    Jun 22, 2009 | Toshiba 32A33 32" TV
    Vertical line in my toshiba laptop
    I have had the issue before on a regular lcd screen. I had to take it in for repair. If it is still under warranty, you should be covered.
    Dec 05, 2008 | Computers & Internet
    Green translucient vertical bar on left side of screen
    Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
    May 09, 2008 | Toshiba 57H82 57" Rear Projection...
    Toshiba 42h81
    Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
    Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
    Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
