Question about Freezers
My frigidaire upright freezer lock won't unlock
  • 9 Answers
SOURCE: freezer only cools to 40 degrees
check to see if there is ice built up on the inside back if there is it may have defrost problems or if part of the back has ice it may be low of freon
Posted on Apr 20, 2009
TheMazz
  • 78 Answers
SOURCE: I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Posted on Oct 13, 2009
ltldab
  • 152 Answers
SOURCE: I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Posted on Mar 09, 2010
  • 523 Answers
SOURCE: 20.3 Cu. Ft. Frost-Free Upright Freezer - White: What could be causing Frigidaire freezer to leak w...
stopped up drain,tear in gasket,not going into defrost soon enough
Posted on May 06, 2010
  • 91 Answers
SOURCE: Upright freezer orange and red
Draw fan has failed, temp unreachable over the past cycle of 24hrs, turn your unit off for 24hrs and defrost it, restart and should work fine for a few days, if so, replace fan and defrost element only. Call service tech for this unless you are clued in on this work, not that costly.
Posted on Aug 28, 2011
HOW TO REPLACE THE LOCK ON AN UPRIGHT FREEZER
Frigidaire does make a metal replacement key that fits most upright freezers. Look on Parts Select. Frigidaire 216702900 Freezer Door Key PartSelect
Jul 09, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How to unlock control panel LFFH21F7HWG?
Press and hold the Control Lock key for three seconds
to activate or deactivate the function. The Control Lock
feature prevents the user from changing the temperature
and freeze settings. At the first press of any key, the
key press click tone will be heard and the display will
show "LO", but no other change will take place. Holding
the Control Lock key for three seconds will activate or
deactivate the Control Lock feature. After three seconds,
the accept tone sounds and the Control Lock LED (if so
equipped) is activated. In lockout mode, when any key
is pressed, the invalid key tone will be heard and "LO"
will be displayed for 1 second. When the lockout is
deactivated, the Control Lock LED is turned off and the
display shows "UL"
if this does not work unplug the freezer for 30seconds then plug it in. if all of the above fails replace the control.
Jul 04, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Lock on upright freezer won't unlock
Could be frozen. Use a hair dryer on the lock assembly and the edge of the lock. After it's hot, push the freezer door in and try the lock then.
Nov 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My new frigidaire freezer is moistening around the door's lock
If mold builds up there you can get really sick!!! it is not supposed to do that. maybe the door lock wasnt put in right and the freezer is making it moist. well you should use your warranty. ... complain like hell too and refuse to pay any service charge if they demand
hope this was helpful
Mar 29, 2010 | Frigidaire Freezer 16.7 cu. ft. Upright...
Upright freezer
just asked a question not needing to pay 10 .00 dollars for the answer can call frigidaire for fee
Apr 19, 2008 | Frigidaire Freezers
Freezers Logo
26 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
