Question about Asko Washing Machines
Asko w6884 seal has come unattached
How do we reattach drum seal?
3 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: The rubber seal has come away from the inner seal
You would need a special adhesive glue made to withstand the heat! But I wouldn't try. Not even Red Green's Duct tape notion could bail this issue. You would have to replace the complete seal. And that...you're probably looking...around $30-50.
Posted on Dec 17, 2009
caroldon
  • 17130 Answers
SOURCE: ASKO w6884 Eco vibrate violently when spins
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Posted on Jun 01, 2012
Replace sealed 1950s three-way switch
https://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Sep 16, 2015 | Electrical Supplies
How do you reattach a coolant hose?
clean it very good an if its smooth then just put it back on clean an clamp it good.
other wise :
get some automotive high temp silicon 5.00 an spread a tiny bit on both surfaces an let set 5 min an don't clamp it till 24 hrs later .
so it has to sit .
or
just screw it an clamp it an it will be some what sealed good nuff.
Jul 25, 2014 | 2000 Chevrolet Silverado 1500
How to fix door leak in ASKO D3231 dishwasher
Almost sounds like the machine was dropped and is out of square. Can you take it out of the install location and check the squareness of it on the drum and the rails? Also if you take it all the way out of the cabinet, you can see the other hinge locations and check them.
Jun 11, 2014 | Asko Dishwashers
Door on drivers side is noisy on 1998 Oldsmobile Bravada
I've seen the weather stripping unattached at the top right where the door angles down to the fender. Use some weather stripping adhesive to reattach.
May 13, 2014 | 1998 Oldsmobile Bravada
Check this link :
May 31, 2012 | Asko Washing Machines
The rubber seal has come away from the inner seal drum after one of the shocks broke. I have replaced the shocks but the seal is off. How do I reattach the seal to the drum? model#WSXH208
Dec 17, 2009 | GE WSXH208A Front Load Washer
My asko frontloader squeeks when the drum turns
It may be the seal needs to be greased (waterproof grease) where the drum shaft goes into the support bearings in the outer drum case--major tear-down! Check the front bearing for looseness or roughness while you are there. Make sure the motor drive belt is not causing the squeak first. Good luck!
Dec 16, 2009 | Asko W660
Printer says it is offline. How do I make it "online" once again? Notification it shows: "The printer is offline. Check that the printer cable is connected and the printer power is on." Printer cable...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi15
Jun 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Maytag atlantis
Red silicone glue will not hold the "fin" under operation. You will have to access the outside of the drum to reattach the fin Avoid removing the drum unless you have the equipment to re-install the bushing that holds the drum. Make sure you disconnect the power and gas.
Aug 31, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Washing Machines Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
