Question about Husqvarna 288 Kill Switch Wire Chainsaw Chain Saw
Setting carb what initial setting should the high & low setting on the carb be 288
    Sergeant:
  • 458 Answers
Gently turn the needle valves in till they stop. Then turn each one full turn out.
Posted on Apr 29, 2014
2 Suggested Answers
  • 149 Answers
SOURCE: need initial carb adjustments for both high and low adj.
start at 1turn out on both that should grt it running from there..
Posted on Jan 31, 2009
What is the initial carb settings on the carb?
screw jets in untill they bottom out slightly then--
high jet one full turn out
low jet one and a half turns out
slight adjustments might have to be made once unit is running
hope this helps
Sep 04, 2015 | Husqvarna Models 181, 281, 288xp
Air adjustment poulan p3816 chain saw
The initial start settings are 1 full turn out on both low and high settings.
Oct 06, 2014 | Poulan Garden
Carb adjustment air and fuel mixture on poulan pro pp330
For initial start: Turn low and high adjustment out 1 full turn.
Sep 05, 2014 | Garden
Settings for carb. on a 42 cc chain saw
Initial settings are one full turn CCW on both low and high side adjustments.
Sep 02, 2014 | Craftsman sears 18" Chain Saw Chain (...
My husqvarna 288 wont start, has extreme high compresion and cant pull cord with the spark plug in it. easy to pull with spark plug removed
http://www.ebay.com/itm/HUSQVARNA-288-CARB-REBUILD-KIT-COMPLETE-TILLOTSON-NEW-/140290773535 Your carb.may need rebuilt,remove and inspect,did you leave gas in it while it was stored,if so then carb is suspect.About 80.00 for a shop to repair,14.00 for you to do it.
Oct 10, 2012 | Husqvarna Garden
Homelite mighty lite 26ss - Carb needs adjustment. Which screw is which? What are the initial low and high screw adjustment settings? Thanks
Starting with the question which screw is which: the low speed screw is closest to the engine and that makes the high speed screw farther away. Set the screws 1 turn out and then adjust as needed.
Feb 14, 2011 | Garden
I need to know the preset adjustment on the low and high idle on a stihl weedeater (ex. 1 1/4 turns)
all 2 cycle weedeater type carb diaphram presets / initial settings are 1.5 turns after a gentle close. You will of course have to dial them in after the initial start.. (1 and 2 screw types)
Jan 22, 2010 | Garden
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husqvarna 288 Kill Switch Wire Chainsaw Chain Saw Logo
51 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
