Question about Panasonic KX-T7730 Corded Phone
Out of range
Do not know how to reset out of range we changes batteries and let them charge for 12 hours phones still say out of range please help
  • 5 more comments
  • Anonymous Dec 31, 2007
    disconnected and tried again. don't know how to reset.
  • juddmo Feb 10, 2008
    We have the same problem with our GE phones. When they get discharged, they show as out of range. We do not know how to reset.
    We sit phone in charger. I have accidentily reset in the past, but do not know what I do. Can someone help??
  • Anonymous Feb 17, 2008
    my phone displays Out of Range.....Do not know what to do either HELP
  • Anonymous Feb 26, 2008
    I do not know how to reset out of range
    please help
  • tsm004 Jun 04, 2008
    I to have these phones. I have three and now only one works. it says out of range even when it's sitting in the base. Has anyone tryed calling for support?
    Let me know
  • baxbunch Jul 10, 2008
    why do i get a constant out of range message and how do i fix this.
  • bijuvarghese Aug 07, 2008
    I also have the same problem but dont know how to solve it.tried every thing in the manual.
    Problem Solver:
  • 14 Answers
On the phone that says, 'out of range' you need to select MENU then scroll down to the option that says REGISTER and select that. Then go to your BASE UNIT and push and hold the PAGE button until the 'bad' phone synch's up again. .... I called into motorola support and they stepped me through this.
Posted on Jun 25, 2008
I have a Radio Shack 2.4ghz cordless phone system and sometimes the handsets will show "Out of range".
My Solution that works for me.
Unplug the power cord and telephone line to the base for about 30 seconds. This seems to reset the base. Then plug everything back and you should be ok.
ET Sherman
Posted on Mar 06, 2008
I had the same problem. I disconnected the power supply from the base and then reconnected it. I hit the flash button on the phone and then put it back on the base and that seemed to reset it.
Posted on Feb 08, 2008
Same problem. I have manual and try to go through deregistering then registering, but cannot get handset into registration menu since it is stuck on out of range.
Posted on May 09, 2008
I need help PLEASE!
Contact your cell phone service provider and ask for help, they can walk you through this.
Jul 14, 2017 | HTC One VX
I phone been dead for over 12 hours now left on the charger, for 2 hours and still no luck. i have tried pressing the power at the the top right and the button at the centre of the phone, aand still no...
Try charging from a wall charger versus plugged into a computer if you havent. Also try removing the battery and reseating it, lastly Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
Nov 18, 2013 | Apple iPhone Smartphone
Hey there When for the first time, i connected my Philips Spark 4GB to my pc's USB, there was nothing in it's display screen and it couldn't be charged. I removed it and tried more. "No changes at...
Try a different USB port. Leave it on for several hours. They sometimes say 12 hours for the first charge. If it still doesn't charge it is defective. Return it.
May 02, 2017 | Philips SPARK Battery
I bought a new batterie and charge it for 12 hours and it still doesn't work'
Please check the voltage on your adapter, then connect to the phone and check the voltage at the battery terminals of the phone - use a good multimeter in 10 volt DC range- If there is an indication of the voltage higher than that of the battery then insert battery and check to see if the voltage has dropped, if so the battery is faulty - possible shorting or that the adapter does not have good current factor. Please use good original battery if you have bought a replacement type.
Feb 18, 2011 | Cell Phones
Working less than 12 hours
tyr to change ur charge
May 09, 2009 | Nokia Cell Phones
Keychain remote needs reset every 12 hours
i dont know if this will work or not but try changing the battery i the remote . we just got our system installed a we have two remotes they installer said they have watch size batteries. hope this helps.
Jan 25, 2009 | GE Security Simon 3 Wireless Home Security...
Battery holds a charge for a short time only
These phones are known for the contacts not transferring adequate voltage to fully charge the phone.
Oct 23, 2008 | GE 26928GE1 Cordless Phone
Kenmore Range clock issue
That works, to change from military 24 hour to 12 hour format press and hold the clock button until it beeps and changes the displayed time, e.g. from 20:01 to 8:01. This worked on my Kenmore Elite Range. If you get the dreaded F1 error, you'll likely have to replace your clock timer board.
Apr 02, 2008 | Kitchen Ranges
Out of Range
Make certain that the phone line cable is plugged securely into the base unit in the back. Disconnect it and re-insert it into the connector firmly. That should do it if the battery pack has been sufficiently charged.....12-16 hours should do it for the initial charge. Of course, you can't ecxpect it to find the base unit if it is 2 miles away, under a metal box! Just kidding!!
Dec 28, 2007 | GE 28112EE2 Cordless Phone
Panasonic KX-T7730 Corded Phone Logo
461 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
