Not working gametracker cs 1.6 - Computers & Internet
How do I get Digital Praise Guitar Praise to work on Windows 7
Navigate to where you installed Guitar Praise (Usually C:\Program Files\Digital Praise\Guitar Praise by default)
Then copy \common\client\prefs.cs to your Guitar Praise ProgramData folder
(Usually C:\ProgramData\Digital Praise\GP\Guitar Praise\)
Then right click and change it's properties so it is no longer read only.
Next open that prefs.cs file in Notepad and change the line
$pref::Video::profiledRenderer = "OpenGL"; so it says $pref::Video::profiledRenderer = "Direct3D";
Also change the Video::allowOpenGL from "1" to "0"
and the Video::preferOpenGL from "1" to "0"
Finally save your changes and watch the game work.
Mar 04, 2013 | Digital Praise Guitar Praise Expansion...
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
C-1120 on a CS 5035
The LCF lift 1 is not working
Jun 10, 2011 | Kyocera Copystar CS-5035 Copier
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Aug 04, 2010 | Maxtor Hard Drive
I have counter strike condition zero installed on my pc. but howw do i play online multiplayer game on it
i need too register on one server to play online with other's here you have an option http://www.gametracker.com/search/czero/
Dec 02, 2009 | Computers & Internet
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
Computers & Internet Logo
David Payne
David Payne
