Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
TV projects a pink/green shadow
My set began projecting a pink and shadow. It only seems to do this with hi-def sources. The s-video input still seems to work fine, it is just the images connected to the tv by way of component video sources that seem to have this problem. Another strange issue is that I have both my dish and dvd routed to my tv by way of my receiver. Both inputs enter the receiver by way of component video cables and then channel through one common cable to the tv. The strange thing is that the DVD image is fine on the tv, while the dish image has the shadow? Is my set just not processing hi-def images correctly. My xbox 360 which is plugged into a separate hi-def input directly to the tv also shares the same problem. Any ideas? Thanks.
  • 1,694 Answers
Logically proceed one source at a time = disconnect all,
then hook-up one at a time or hook-up seperately.FYI, the
RF coax , composite and s-video inputs all share the same
circuitry, whereas component is a whole seperate video
processing circuit, with another difference between 480P and
1080 I . Sounds like you have a 1080 I problem, which might
be a little sister board..............................T.
Let me know..............Thanks.
Posted on Nov 12, 2007
Can the lens on a rca rear projection get dusty and cause blurry word and images?mostly words on my video games are unreadable is hooked up via componite cables..running at 1080i..i have tried auto...
All ur convergence + - colors lines matches up wright?Yes.Than no,this problems are ur CRTS tubes colors guns R,G,B have bad CRTS coolant chemicals.Tries websites like, to buy a coolant kit to changes those CRTS coolant chemicals,should solved ur tv problem.
Nov 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My HDTV seems to be very Low Def - Panasonic Projection PT47WX54J
Ur convergence it dead.Must replaced the 2 convergence ICS.Know how to solders?Tries Tv repair, for the convergence kit to repair it ur self.The Shop will cost U $300 parts and labors.
Jan 27, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I want to know if you have to turn on the HD conponents cause i tried to use my xbox360 and thier is nothing on the screen. i already check the xbox360 wires and they are fine.
If you are using a high def tv and u want to play with hi def graphics, u must put the switch on the xbox av/component leads to HDTV, otherwise,standard def will be used. Check the tv input by using a dvd player or another input source to confirm it works. Good Luck.
Nov 16, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
My Philips 51PW9363 has pink and green colors only!!!!
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
Jan 05, 2009 | Philips 51PP9200D Television
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
54 in big screen phillips hi def tv picture has green shadow all around it.
Does it look like a glowing halo, and makes the set impossible to adjust it out? Please respond to this same post I may be able to help, as it sounds like a coolant problem, very common in phillips TVs
Jul 19, 2008 | Televison & Video
Getting there...
You would need the service manual and actually trouble shoot the input circuits. If you would like a link where you can purchase the manual and have it emailed instantly to you let me know. The service manuals there are cheap and the quality is exceptional.
Mar 13, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55857 55 in connection problem
there is a setting in the menu under setup i believe it is called
"LABEL VIDEO INPUTS". check you owners manual. you need to make sure that
the DTV input is set to YPbPr NOT RGB.
Feb 22, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Picture problems
My computer did this and I think my TVs just gone the same way. Was definitely a loose connection somewhere. In the computer monitor it was because the pins in the plug were slightly bent and if I moved the wire the picture got better. In the end I had to replace the connecting cable
Mar 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
