Question about D-Link Dcs-942l Web Cam
Dcs-942l after 5 minutes hot and stop working
Is the SMDV 10 SM 512 hot shoe safe sync the same connection for all digital SLR cameras?
Most brands of camera's do have own hot shoes for the flash light. That is because they al have a different protocol for starting and stopping a flash, when the camera should measure the amount of light coming back. (TTL or through the lens)
And perhaps, to keep costumers to their own brand?
I found my Nikon commander is capable to trigger my canon flash too, but only to start it not to stop. so the flashes accept commands from more than one brand.
Apr 12, 2014 | SMDV Hot Shoe Safe Sync Adapter SM-512 for...
Dcs 942L steady red light
If it is under warranty, then exercise the warranty to get it replaced.
Nov 23, 2013 | D-Link DCS-942L mydlink-enabled Enhanced...
All 6 ranges and the large oven work well.the small oven won't li
My gas oven stopped working properly - called in the repair man and he replaced two of the three ceramic ignitors. (I have a two oven model). Apparently they only last / work well for 3-5 years. Kinda sounded crazy to me - but verified on the internet they are required to be replaced. Not sure I'd call the repair man next time - get the part yourself, one screw & two wires to replace. I'm no expert - but that solved my problem.
May 22, 2010 | DCS RDS-486GD Stainless Steel Dual Fuel...
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
DCS elect wall oven LCD display
Had the same display issue with my DCS WOS-230. The display was fading and made it very hard to read clock and temp setting. Called DCS/Fisher Paykal and was told I need the Control system kit for $335.00 to fix the issue. After reading the input on this issue on this site I pushed them to sell me just the DCS EOC 211696 double display module 100-01095-00. Install took 10 minutes and everything works great. Thanks all for laying the groundwork as DCS will really push hard to sell you the more expensive kit that you do not need.
Jul 17, 2008 | DCS WO-130 Stainless Steel Electric Single...
D-Link Dcs-942l Web Cam Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
