Question about Honeywell HHT-011 Air Purifier
Red light glows top machine - Honeywell HHT-011 Air Purifier
My xl-15 air purifier works but it does not blow out air with the purified smell. I think I see people calling it ozone.bthere used to be what looked to be an illuminated orange light behind the fan. It...
Easy. You need new plates in the machine. They cost about $15 a piece. Google 'ozone plates for XL-15' & sources will come up on where to buy them. Remember to clean the plates every 30-45 days w/ 50-50 solution of ammonia & water & a tooth brush on these plates. Dry thoroughly w/ hair dryer before putting back in machine.
Feb 15, 2011 | Alpine Air Purifiers
How do you reset the machine, to get rid of the flashing red light after changing the filter?
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking.
Dec 09, 2010 | Filter Queen Defender Air Purifier
I have cleaned the machine and the red override light is still on
Are you sure the filter cartridges are in correctly.
Those can be tricky if they are not in exactly the same way. The metal tabs have to line up. Also, isn't there a reset button on those?
Hope that helps,
Matt
Sep 19, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Ionic Breeze Professional GP series.....question regarding lights
red light will not go off what do you do or is it still working or not and the red light is just on
Apr 04, 2009 | Sharper Image Professional Plus Ionic...
Red light on holmes 422 hepa filter air purifier.
What is the complete model number of the unit?
Two types of a 422 popped up on their website.
Oct 27, 2008 | Air Purifiers
Sharper image quadra silent air purifier has red light flashing
Have you cleaned the bars lately? I believe that red light means that the bars that collect the junk from the air are at capacity and needed to be wiped down.
If you don't know how to do this, pull them out from the top after having turned the machine off. Get a rag or paper town moist, but not dripping and just wipe the black soot off all visible sides of the metal bars. Lay it aside when done over night for it to dry completely, then re-insert them into the machine. Turn on and hopefully that should take care of it!
Jun 18, 2008 | Sharper Image Professional Plus Ionic...
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
Hepa filter
The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
Aug 22, 2007 | Holmes Products HAP422-UC Air Purifier
Honeywell HHT-011 Air Purifier Logo
55 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
