Question about Drills
Wilton strand machining systems drill - Drills
4 Suggested Answers
  • 77 Answers
SOURCE: I need a manual for a Wilton 25pr radial arm drill
Posted on Jul 20, 2009
  • 302 Answers
SOURCE: dayton drill press, How do you remove the chuck?
If the spindle has a slot in it above the chuck and you can see the top of the chuck arbor in that slot then you need to get a wedged piece of steel commonly called a drift , insert in the slot so it bears on the top of the arbor and the top of the slot and hit it with a hammer. This will knock the tapered arbor loose from the spindle and it should fall out. Hope this helps you.
Posted on Jan 27, 2010
  • 165 Answers
SOURCE: What type of lamp is used in a Wilton Strand drill
Probably a rough-sevice bulb.
Posted on Feb 28, 2010
Wilton planer 99178
Walter Meier took over the parts division of Wilton, they are based in Europe. The website is not up to speed.
Dec 10, 2013 | Tools & Hardware - Others
How do you change the chuck out?
if it has a slot in the spindle, there was a wedge that came with it, put the wedge into the slot and strike it with a hammer. depending on the taper fit you would need something like a ball joint seperator to knock the arbor from the chuck body. that is the best I can do without knowing the model and brand of the tool
Jan 25, 2011 | Wilton Drills
Dayton drill press, How do you remove the chuck? It has a Wilton 1/2 chuck 3z568 model
Jan 26, 2010 | Drills
The drill bit shaft falls out of the housing when coming up from making your hole.
you can try using something like brake clean and spraying both the shaft and internal socket and then wiping with a paper towel. next move the table out of the way and place the shaft back into the socket with the chuck jaws retracted take a block of wood and a hammer and "tap" seat the tapers together. I would "tap" it a couple times and this should work if they are not worn excessively.
Nov 19, 2009 | Wmh Tool Group Wilton 2530 15" Bench Drill...
What voltage does a wilton model 2320 need to run on
went thru their whole site and found nothing listed with your model number. I suggest calling their technical hotline at 1-800-274-6846 M-F 7AM to 5PM CST for the information. wish I could have helped more.
Oct 10, 2009 | Wilton Drills
Need a chuck for this drill
what is the chuck mounting size or taper? It should be stamped in the chuck itself, let me know what you find and what area you are in city, state and zip and I will try and find one near you.
Oct 09, 2009 | Wilton 2223VS 20 Inch Variable Speed Drill...
Drills Logo
46 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
