Question about Vehicle Parts & Accessories
Prostart;antana red light stay on car will not start
I have a Prostart CT-3371 when I press the start button the lights on my vehicle flash on and off 10 times but the car will not start?
The hood is open, or at least the system thinks the hood is open. Look for a damaged pin switch under the hood and try disconnecting the wire.
Mar 07, 2016 | 2008 Toyota Highlander
I have prostart 3 way new installed into 1995 f250diesel can't get remotes to conect to the prostart brain box
Verify batteries are installed and installed correctly in the remotes. Examine the batteries and the battery holders on the remotes for "shipping isolators", pieces of plastic film or tape that insulate the batteries from the battery contact points. Verify the batteries are fully charged with a volt meter. Beyond these basic check points, contact prostart support.
Jan 19, 2014 | Cars & Trucks
How do I reprogram Prostart remote starter/car alarm after replacing car battery?
Try turning the Prostart off, then on with the little toggle switch. Check that the hood pin switch is working as it should
Dec 03, 2013 | Cars & Trucks
Prostart
see the diagram attached. and fix it. God bless you
Jul 11, 2013 | Computers & Internet
Pontiac mini van 1998 transport, V6, 3.5L I left lights on and when I came back found my car battery died, I get boosted, since then my prostart two way 3 in 1 remote starter never work. Last winter I...
you will have to unhook your prostarter or get someone to replace its burnt from charge then after pro start is unhooked then put battery back in the turn key over.
Feb 13, 2011 | 1999 Pontiac Montana
Radio signal strength not very good
It is due to the vehicle antana. you need to purchase a antana booster. hook it to a 12v power plug antana from car to one side of booster and radio to other side. this will increase signal from car antana to radio and should fix problem. most boosters can be found at any car audio or truck stop and run from$10.00 - $25.00 good luck
May 21, 2009 | Goodmans CD car radio GCE358MPT CD Player
Pro start car starter problem
I have a problem my light in the the antana stay on but wont flash and the car wont start either so how do i fix it
Jan 28, 2009 | Vehicle Parts & Accessories
How to program a remote control prostart in a jetta 91
Sounds as if the device is now out of the warrenty by now. any Devices like this are common to break down. Im surprised you got 6 years out of the bugger. the companys want you to buy new ones. you can try checking the prostart website fora replacement remote, but the cheapest way out is to goto a wall mart and get a new remote start.
Nov 10, 2007 | Computers & Internet
Vehicle Parts & Accessories Logo
18 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
