Question about Nortel Contivity VPN Switch 1600 (DM1401058) Remote Access Server
Netgear WPNT834 wireless not working
My router has developed a problem with wireless acess. When I view the available networks, on any system with wireless capability, I see all my neighbors, but can only see my router occasionally, and cannot connect through it. The settings are WEP, shared key, 64 bit, running on channel 6. It used to work, but for some reason, it doesn't show up in the available list anymore. I've turned the unit off overnight, but the problem is still there. Does wireless gateway functionality fail? Is there any way to fix this?
  • 1 more comment
  • Anonymous Nov 23, 2008
    ASUS WL-500gP V2: Wired is O.K.
    My Wireless card (broadcom also) 'connects' to the WPA-PSK network, but nothing can pass through it. No ping (Static IP), No DHCP. It`s configured in bridged mode with lan. Router is configured to be access point.
    Firmware is OpenWrt based DD-WRT v24-sp2 SVN revision 10776M NEWD Eko
  • bungys Mar 01, 2009
    I too have just returned to see that my wireless element is no longer radiating. I have tried both a warm and cold boot, both to no avail.
  • Anonymous May 11, 2010
    to star, how is your AP connected, home connection, server machine. Do you have a firewall installed, is your AP installed correctly, check in device manager to see that there is no problem. How is it connected to your PC, usb or lan ???
  • 196 Answers
This could be some kind of interference. Try changing the channel.
Posted on Oct 08, 2007
SOURCE:
How do I secure my netgear wireless router? I tried to enter in the http://192.168.0.1 but it isnt working? Please HElp
The default IP address of the Netgear WGR614 is 192.168.1.1.
Or try typing http://www.routerlogin.net in the address bar of your browser.
By default, the username is admin and the password is password.
To secure your wireless network, Go to Setup -> Wireless settings.
Change the SSID (wireless network name) to easily determine which is your wireless network.
Enable WEP and make sure you take note of the network key.
On your wireless computer, view the available wireless networks and you should see your SSID. Then enter the network key.
I hope this helps!
Jun 21, 2010 | NetGear WGR614 Wireless Router
Laptop Winxp suddenly not seeing wireless network. Vista 64 main computer and Netgear WGT624 wireless router appear to be working fine.
Are you using the WZC on your WinXP computer of the wireless adapter's software utility? Try to reboot the computer and check on the system tray if you will see the computer icon with a red X, right click it and select view available wireless networks, if it cannot see anything... Go to Start, All Programs and look for anything that pertains to wireless adapters open the utility and refresh the list of wireless networks available.... if you see your wireless network name, select it and hit connect
Mar 27, 2010 | Computers & Internet
I have a WPNT834 and even if I open the related port on it, my xbox is always on NAT strict, what can I do to solve this problem ?
First of all delete the port numbers you forwarded and upgrade the firmware on the router.Follow the link below where you will find the information on how to upgrade the firmware:-
http://kb.netgear.com/app/answers/detail/a_id/896
After upgrading the firmware open the ports for the x-box with the ip address of same as that you have on the x-box and then try for the connection test.
Nov 20, 2009 | NetGear WPNT834 Wireless Router...
Netgear tich not lighting up
The Tick light should only come on when the netgear first starts, and when all the checks are complete and OK, it goes out. First, make sure you computer wireless is turned on, Next, go to the lower right of your screen to the system tray where there should be a monitor icon with an"X" on it. Right click and select "View available wireless networks". Select your router name and click "Connect" You should connect and be able to get on the web. If you set up security, select your network and click connect. Type in your KEY and then you should connect to the web.
Jun 11, 2009 | NetGear WGR614 Wireless Router
Netgear wgt624 with WGt111 usb wireless connection showing red no connection when using netgear wizard programme
Follow the steps to configure wireless connection :
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connect
Jun 08, 2009 | NetGear WGT624 Wireless Router
My netgear wgr614 is not working. I have no
To establish a wireless connection between the router and computer, the router’s wireless setting (SSID or Network Name, Channel, and Mode of communication) has to be configured. Please follow the steps below to configure the wireless settings on your NETGEAR router.
  1. Connect a computer to the LAN port of the router using an ethernet cable.
  2. Open up a browser and type in the following URL: http://192.168.0.1 or http://192.168.1.1 (depending on the model number of the router)
  3. Type the Username as admin, and Password as password. Then click OK.
    1. To change the Wireless settings, click Wireless Settings under Setup on the left menu bar.
  1. Under Wireless Network, (make a note of these settings, you need these values to configure your wireless clients)
2.
    • Change SSID from default NETGEAR to any desired name (for e.g. Home)
    • Select the Region as applicable - Incorrect selection may cause performance problems.
    • Select any one of the available Channel.
    • Apply the changes
Configuring Wireless Clients:
The steps explained below use the Windows XP wireless client. If your card came with
its own wireless configuration utility, you may use that as well.
  1. Open the Control Panel from the Start Menu.
  1. Right-click Wireless Network Connection and choose Properties.
  1. on the Wireless Networks tab and if unchecked, check the box for Use Windows to configure my wireless network settings.
Then click OK.
  1. Right-click on Wireless Network Connection, Select View Available Wireless Networks
  1. This will lists all the available wireless networks in range. Select your network from the list and click Connect.
If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key (if you are using WEP security, make sure you are typing the network key, not the Passphrase) and click Connect
  1. Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wirelessly.
May 18, 2009 | NetGear WGR614 Wireless Router
Need my passphrase for my netgear wpn824 wireless router
Are you trying to setup your router? If so..
Here is a list of Netgear WPN 824 Models. :) USERNAME PASSWORD
Netgear WPN824 v2 (Netgear Firmware) admin password Netgear WPN824 v3 (Netgear Firmware) admin password
Netgear WPNT834 (NetGear Firmware) admin password
Jan 07, 2009 | Computers & Internet
Hi Ashdan
channel 6 is very common with 2.4ghz wireless phones. Try changing the channel to a different one ie. 2 to -5 is rarely used so i suggest one of those. Also WEP is very insecure and easily hacked. If the only risk is people stealing your internet then i suggest you use MAC filter as the most secure way and turn off wep. This will make your router and internet surfing experience even faster.
good luck
smeags.
Jan 02, 2008 | Gateway 802.11g Wireless DSL/Cable Router...
Problems connecting to the internet with my wireless laptop
At the bottom right hand corner of your screen, you have a wireless conenction icon. right click and view available wireless network...if you see your network there. connect to that network, if secured, then call netgear to verfiy what is your network key. if it is unsecure then you can log on right away.
Oct 13, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Wireless router
Have you tried inserting the included cd into your drive and follow the instructions in the SmartWizard yet?
Sep 16, 2007 | NetGear RangeMAX 240 WPNT834 Wireless...
Open Questions:
See all Nortel Contivity VPN Switch 1600 (DM1401058) Questions
Nortel Contivity VPN Switch 1600 (DM1401058) Remote Access Server Logo
311 people viewed this question
Top Nortel Computers & Internet Experts
Vuk B
ray gallant
ray gallant
Robert Karst
Robert Karst
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
