Question about Kenmore Washing Machines
No H2O error on my brand new kenmore 417.4110
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: error code 32 on a brand new kenmore HE 3T wash machine
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
What is F1 failure code on a kenmoore oasis washer
check your owner manual section troubleshooting for error code very important.
Normally this error code can be meansL a) pressure out of range.
or b)eepron error.
or call the factory and get support online via chat or phone for to fix it.
God bless you
Sep 25, 2012 | Kenmore 4.7 cu. ft. High-Efficiency Top...
My PTG-42PVN h20 heater is allowing h2o temp to fluctuate from one extreme to another.
Does same thing happen at all faucets?
Are you getting error code?
You might have crossover problem with defective faucet cartridge.
Copy following links for troubleshoot resources:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Aug 08, 2012 | Rheem Water Heaters
I have a Kenmore 80 series top load, direct drive washer. It will fill with h2o but will not agitate or spin. I had changed the moter coupler prior to this new problem and I rechecked it and it looks fine....
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the whirlpool / kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd first pull the cabinet and completely remove the motor coupler, check that the holes in the center rubber piece are intact and then replace it.
If the holes in the center piece and the prongs from the plastic pieces aren't ligned up correctly when re-installing it, you can strip the center unit. It would look fine from a glance but wouldn't be able to drive the gearcase.
Since you CAN hear the motor, the problem does point to the coupler:
Also see the following for a detailed description of how to replaced it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=0da65cea0e338fe930b1fde153a243f0
Feb 16, 2011 | Washing Machines
My 800 kenmore washer is filling with h2o, then sets for a while, or does nothing then i touch the dial ans no spinning, it just releases the h2o
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Mar 06, 2010 | Kenmore 15864/15862 Top Load Washer
FH error on Kenmore he4t only happens when using hot or warm h2o
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem. Always first check your hoses if you have flood hoses get rid of them next get a bucket and see if water is comeing out of the hoses next check you inlet valve screens see if there is sand in them if there is clean them.
Jun 11, 2009 | Kenmore Elite 45986 Front Load Washer
Error code 32 on a brand new Kenmore HE 3T wash machine
Apr 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Ariston Margherita ald 1 40 Error code H2O
H2O is the symbol for WATER and probably indicates a WATER related fault on your machine. A pressure switch is the normal way the machines 'sense' when the level is sufficient. Overfilling suggests a faulty switch, which will need to be replaced by a technician. Also, ensure that the machine drains as it should, if not, the pump filter may be blocked.
Jan 03, 2018 | Ariston Technologies Washing Machines
Kenmore front loading washer
brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
H2o error
I checked everything I posssibly can and ended up booking an engineer who will be here Monday. I'll post what he says and whether or not it's DIY fixable.
Apr 03, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
61 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
