Bearing and seal on maytag washer model sav3655aww
Tub bearing loud and seal leaking
  • 86 Answers
SOURCE: Maytag SAV washer leaking all over floor
I have the exact same washer with the exact same problem. I have a home warranty that covers appliances so when they sent out the Sears technician, he took a list of parts and replaced about 9 things for a grand total of $450. If I didn't have a home warranty that only charged me $55 to do it, I would have just bought another non-Maytag washer.
Posted on Jan 23, 2008
SOURCE: Maytag Legacy Series Leaking
I have the same problem as many other Maytag owners of this model machine have. I spoke to a repairman and he told me to "junk" the machine. He said the cost was about $300 to $350 to fix and he WOULD NOT guarantee his work on this machine. He said that Maytag knew of the problem but refused to do any sort of a recall.
My solution:
1. Buy another machine and junk the Matag
2. Tell all your frends and neighbors NOT TO BUY MAYTAG...
3. Drop the old machine off on the MAYTAG door step.
Posted on Feb 19, 2008
reg501
  • 413 Answers
SOURCE: I have Maytag LAT2500AAE. I took
Tub bearing replacement on ANY Maytag can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Maytag washers require specialized tools for removing certain components of the machine.
Posted on Jun 01, 2008
blueextc3221
  • 15935 Answers
SOURCE: Worn out drum bearing and seal
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
SOURCE: Loud noise during spin cycle (Bravos washer) was
Similar issue, lot of racket on final spin and was told only option was a $280 whole tub assembly. Dissasembled tub and removed bearings from shaft. Took to local bearing warehouse and got replacements for <$25. The small one was a Nachi Quest 6005-2NSE9 and the large one was 6006-2NSE9. It took me @ 4-6 hrs in total and had to work to get top bearing onto shaft but much more attractive option than replacement or whole tub. Extremely irritated with Maytag and will NOT give them another dime. A appliance less than 1.5 yr old should not have these issues - cheaply made. Is a shame as Maytag used to mean something, it meant quality but not anymore.
Posted on Sep 24, 2011
Washer drum making loud noise when spinning
Reach into the drum (on a front-loader)and push upward to see if it moves at all, you should feel no play where the drum support shaft passes through the bearings... The bearings will "roar" loudly during spin if the main seal has leaked water into them... Top-load washers will exhibit the same roaring if the seal fails in them also. Whirlpool Tub Seal and Bearing Kit W10435302
May 13, 2016 | Washing Machines
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Kenmore Elite Oasis Top Load Automatic Washer Model 2708 When spinning it makes very loud noise. Also water leaks out the bottom when in operation
Sounds like the main outer tub and bearing assembly is bad. Water has(is) leaking through the main center seal, through the bearings(noise your hearing is these bearings) The tub and bearings with seal and center shaft come as a assembly, not a inexpensive repair. Also the water is getting on a little electronic board called the roto position sensor which can fail, found as part of the motor assembly on the bottom. Causes corrosion on the connection to the wiring. Your main problem is the outer tub assembly........ Good luck.......(I would also suggest you unplug the drain motor(some have a recirculation pump also) to make sure while spinning empty to run only the main motor that this is for sure the noise and water leak if this is your first repair)
Sep 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Makes loud noise in spin cycle
The problem is that the seals are leaking and allowing water to attack the tub bearings.
You need new tub seals and bearings.....not as difficult as it may seem.
see u tube video on replacing maytag seals and bearings
Cheers Stan
Aug 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
IT LEAKS WATER AND IT MAKES A REAL LOUD NOISE WHEN IT'S SPINNING..
your drum bearings and tub lip seal are defective,it requires you to remove the rear access panel and the inner drum,then remove bad seal and bearings
Mar 09, 2010 | Washing Machines
Very loud on high speed spin cycle Sounds like jet turbine Frigidaire Model FWSB67RGS0 almost 10 years old. Was given to me. Don't know if it has always been this loud.
Most likely the tub seal on the bottom is starting to leak water onto the bearing under the tub and now the bearing is starting to go bad.
Jan 01, 2010 | Washing Machines
Loud spin cycle - leaks water
No boot on a top loader, the tub seal and bearing are gone, water leaked from the tub seal, rusted the bearing and quite possibly the milk stool and transmission. Check your warranty, the transmission may have a 5 year limited warranty, usually it will include the tub seal and bearing with the kit.
Jun 13, 2009 | Maytag Atlantis MAV9501E Top Load Washer
How do I remove the inner tub from machine to get to the bearing and seal. There has been a loud whine when the machine is in the spin cycle, and now it leaks from the bottom of the tub. I need to replace...
whine could also be from motor bearings and also from motor brushes. leak is not necessarily due to bearings. to help localise leak, put a sheet of newspaper under machine when in cycle and this will give you a good idea where leak is.
Sep 29, 2008 | Maytag Washing Machines
Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Jul 20, 2008 | Amana 3.2 cu. ft. Top-Load Washer
VERY LOUD GRINDING NOISE LG WM-2277HW Front Load Washer
Get a new washer. Perhaps another brand.
The fix for me was to get a new washer. Had same issue with loud spin cycle. Tried researching while wife was continuing use of washer. Then the LE message appeared.
Took back apart and found that water had leaked and caused a boat load of damage. Bearings shot, seal leaks, drum leaks, Stator damaged. Same issue as 'jammy64' stated.
Cost to repair wasn't worth it. Going to get an
Electrolux model.
May 19, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
