Question about Gaggenau Freezers
Gaggenau sk535-264/2 i have replaced h/v l/v pc boards worked fine for a day but know no switches on the front display are respondind but refrigeration side is working i suspect the plug in tape wire on the display board faulty anyone come across this problem beforeb thanks for any suggestions fault finding
2 Suggested Answers
arikrom
  • 528 Answers
SOURCE: Eterna Side by side refrigerator had a ERC board
what is your model #?
contact me at www.911servicetoday.com
Posted on Dec 30, 2009
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
GE GSS22JFMCWW
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
these are the usual suspects.
heater in the back wall of the freezer:
thermal switch also in the back wall of the freezer
Aug 11, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
GE bottom freezer stopped cooling sporadically every 1-2 days then cools again with no intervention. Unit is 5 yrs old.
Put the old board back in. See what it does, from your post, sounds like it was working correctly.
Numerous problems with upright ge freezer fuf14svarww. Most of the time the same problem occurs. The freezer display will be blank and the freezer simply is not operating. If power is disconnected then...
I believe it is the=>WR55X11084 Main Control Board
There is not much there other than the overload and start relay that if they malfunction it will be a possible to overload the electronic components on the WR55X11084 Main Control Board so I would begin by replacing the main board first. If you notice problems with the compressor starting then replace the start components, Thanks John Tripp John Tripp Appliance 911
Mar 04, 2014 | GE FUF14SVRWW Upright Freezer
Hello We have a gaggenau 2 door fridge freezer,SK 533. And it keeps tripping out the electrics. We have tried running it off a different fuse box and still it happens. Can u help?
Sounds like the defrost element in the freezer has failed in spectacular form, this is the most common fault for tripping power, or it could be the thermostat but this is highly unlikely.
If you can, gain access to the element by dismanteling the panel inside the freezer, the element will run at the base of the cooling cores with a wire at each end (black) and an earth point (green), check with multi-meter, on earth and one on black, check both ends of black. You should find you will have a flow through one of the ends that will indicate a short curcuit, replace the element if faulty.
Regards Russ
Dont forget to vote and if you need more help, email me at wgheaven@yahoo.com.au
May 08, 2011 | Gaggenau Freezer RF461700
Fridge freezer stopped making ice digital display has gone off at the front of appliance, when you open door lights flicker and it makes a noise.
I have seen this a few times on whirlpool refrigerators. There is likely a high voltage board mounted inside a grey or white box mounted next to the compressor. The noise is usually eminating from this box, and replacing the board will solve all of your problems most likely.
Sep 23, 2010 | Whirlpool Freezers
Sub Zero 5065 Under Counter Ice Maker
We have a sub zero 5065 in our storage, still unused and in the box. You may want to just buy it at a good deal. Make an offer, it has to go as we are cleaning out the storage are. 360-695-3238 Brian
Mar 18, 2010 | Freezers
Whirlpool ARC7612 ? intermittent operation
these units has a bad mother boards.
Oct 04, 2017 | Whirlpool Freezers
Power on but fridge/freezer not working (only lights)
Yes, boards may need replacing, but not at the expense of the door, apparantly your "engineer" would rather work on older models that may require a hammer. Best advice would be given knowing the make and model number of your unit. A professional should be able to diagnose the board processes as well as the compressor in a short amount of time. Check the defrost heater (after pwr is restored to unit) for the freezer side (placement depending upon model) for continuity (basically a heating element for the evaporator coils - which will freeze without defrost). Proper defrost will help lessen the load on the compressor. Check the overload relay on the compressor itself for failure and replacement of relay. Have the unit defrosted, svc defrost htr, thermostats/thermolinks , compressor, before checking computer board operations.
Oct 25, 2008 | Freezers
Freezer temp display beeping and going through different temps rapidly!
Seems that you may have a faulty temp control switch or it is stuck in position. Check this also make sure that the air vents are clear.
Thanks J
Feb 16, 2008 | Freezers
Freezers Logo
71 people viewed this question
Top Gaggenau Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Gaggenau Freezer Expert? Answer questions, earn points and help others
