Question about Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Flickering screen upon playback of vhs tape
I record from television on a daily basis, recently when doing playback on vhs tape, the video flickers and neither digital or manual tracking stop the flicker. I have tried other vhs tapes but get the same problem. Any resolutions?
4 Suggested Answers
SOURCE:
  • 197 Answers
SOURCE: Playback Problem
open the recorder, 4 screws at each corner, wipe the playing head and the voice reccognition head, to the right of the playing head head with a baby wipe, you will be amiazed what **** comes off it. DON'T scrub it just wipe lightly, spin the playing head so it's clean. If you have a lint free cloth ( a glasses cleaning cloth you get in the case is brilliant) Try the tape (before you put it in make sure everything is DRY!) and your problem should be solved. It worked for me! and that came from a TV engineer
Posted on Jul 15, 2009
SOURCE: 36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Posted on Aug 17, 2009
walesarumi
  • 6993 Answers
SOURCE: Toshiba V231 UK VHS manual
I believe you are using a RF wire Connecting a VHS, then searching TV station is an old way. I would recommend you use a RCA wire. By so doing, you won't need to tune any station on your TV. All you need to is select Source (AV) on the TV and the VHS would automatically display on your TV.
Below is what the RCA cord looks like:
The yellow stands for video (display), while the red and white stands for audio left and right (sound).
Purchase this cord from any electronics part store within your area, it's not expensive at all.
Look at the back of your TV, connect the yellow cord to "Video IN", connect the red and white to "Audio IN". Then connect the other end of the cord to Yellow: "Video OUT", and red or white to "Audio OUT", at the back of the VHS.
After the above connection, turn on the VHS, insert a tape, and press play. While the VHS is play, turn on the TV, select Source (AV) on your TV and your VHS will start displaying and you will hear sound.
I hope the above is clear. If you need further assistance, please let me know.
Regards.
Posted on Sep 20, 2011
My family videos are stored on the mini VHS tapes. I recently bought a VCR to dvd recorder to transfer them into dvds but now I discover my VHS playpak (that you need to play the mini tapes) is broken....
Maplin Electronics have a motorised VHS-C Cassette adaptor that will enable you to view any camcorder tape on a standard VHS. If that is any help priced around £15.00.
Mar 14, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
VHS to DVD: audio and visual dont match on playback
Hi, this is a problem with cramming too much info onto dvd.
For a good quality dvd, it needs to have about 1.5 to 2 hours of video on it. The more you put it the lower the quality it becomes. Don't forget though , it will never be better than the original.unless you have some specialist software to tidy up sound and flickers in the video.
So I would stick with one tape to one dvd if you want to keep the quality.
DVD's are cheap anyway, you can buy a spindle of 50 Verbatims for £10.
I hope this has helped you understand a little better, but if you need more assistance, then please ask.
Regards - Anthony
Feb 11, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
CCD-TR705e Sony video recorder hi 8 playback 3 beams
the camcorder flickers when viewing playback - pictures flickering
Dec 10, 2008 | Pure Digital Point and Shoot Video...
Flicker on playback
Could be tracking, dirty / faulty heads, or mis-alligned guide rollers.
First,adjust the tracking on the player during playback. This is done by pressing P+ or P- on the remote control.
If this doesn't work, use a video head cleaner. This consists of a video cassette and fluid. Follow the instructions with the cleaner.
If this still doesn't help, and you are confident in opening up the VR550, you could cleaner the heads manually.
Disconnect from the mains.
Remove the screws from the back and sides of the VCR.
Gently ease the lid off the machine.
Locate the large silver coloured head drum towards the back of the machine. There are four small receptors around the side of the drum. These are the video heads.
Take a small piece of clean white paper about 1.5 inches square. (Copier paper)
Hold the paper square over 1 finger and rub each head in turn. Keep the head near the centre of the paper so as not to catch the heads with the edges of the paper.
Check the paper for dirt from the heads.
Reconnect the player and try a tape. If the problem is still there, try cleaning again.
If none of this works, insert a tape NOT recorded on this machine (Mis-alligned rollers affect recording as well as playback) and play. Locate the rollers which guide the tape around the mechanism. Particulary either side of the head drum.
The rollers have adjustments on the top, which can be turned to move the guide up and down slightly. This is a fiddly job, and over adjustment could cause the tape edge to be damaged.
Adjust the rollers to get a clear picture. It is mainly trial and error.
If all fails then the video is probably destined for the skip.
If you need a replacement, www.cheapestelectrical.co.uk , will sell you a VR550 at a very good price.
Apr 09, 2008 | Philips VR550 VHS VCR
Flashing screen when ps2 or dvd player is plugged into my LCD 3201C
I had the same problem!
This TV does not go down to a 480 resolution! If I know that, I would of never bought this TV. I cant use my VHS, PS2, Nintendo (Original). So now I'm trying to save money to get a 120Hz HDTV :P
Feb 23, 2008 | Dell W3201C 32 in. LCD Television
Panasonic nv-rz15
ihave problem with my jvc camcorder,firstly the does not go in itself i have to hold the tape after awhile it sits in but when ipush any button to play rewind etc on screen it says that you needto reinsert &safeguuard is on when its no. will the head cleaner solve the problem or shall i take to repair it.please answer as quick possible thank you. Mrs Bahia
Mar 05, 2007 | Panasonic NV-RZ15 VHS-C Analog Camcorder
Noise block doring playback of D-VHS tapes
* Do not record program in DVHS mode on an S-VHS cassette. Use of S-VHS cassettes will not allow for maximum performance and may result in head clogging. Use only D-VHS cassettes as recommended in the instruction manual on page 27. * Make sure that the DIGITAL 3-DNR lamp is ON when playing back a cassette recorded in D-VHS mode. If not press DIGITAL 3-DNR so that the DIGITAL 3-DNR indicator illuminates. * When block noise appears on the TV screen, clean the video heads with the DFC-2 D-VHS Head Cleaning Cassette (continue up to 3 minutes total). Please refrain from using any other head cleaning cassettes as drum damage may result.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Toshiba MW20FP1 20 in. TV/VCR/DVD Combo Logo
784 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
