SOURCE: Motor is humming loudly.
Motors hum, and your right, it could be no worse than normal.
I would be suspect that there is a gear stripped in the gearcase, since this is a direct drive washing machine.
Reassemble the motor back onto the washer. Run it through a cycle manually (rotate the timer by hand) until the motor turns, then look to see if it's turning. If it is, or even more so, if it pumps water out of the tub, then it is probably the stripped out gearcase.
Reply with you findings and more advice.
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
SOURCE: Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Testimonial: "Thank You! The diagnosis confirmation and repair video helped. There were some differences between my Washer and the repair video, but figured it out"
SOURCE: Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
SOURCE: Kenmore washer burning smell after motor coupling replaced
I have the exact same problem, which is why I found this post. Did it stop, or did you find a solution?
