Question about Cuchen Premium IH Pressure Rice Cooker 6Cup
I need to put my cuchen cooker to english
It is in korean
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
Presssure valve to be turned off or on when using pressure cooker
pressure cooker cooks by the pressure inside the cooker.
So you need to put those on when cooking.
The excess pressure will automatically drain off.
Jun 12, 2012 | Nesco Electric Pressure Cooker
LOOKING FOR AN ENGLISH MANUAL FOR A CARREFOUR SLOWCOOKER MODEL HSC 290-10
I need an English manual for Carrefour Home slow cooker HSC290-10
Dec 26, 2010 | Crock Pots & Slow Cookers
Use of an old slow cooker
NO!
it should say on the metal below the ceramic pot to not get it wet
slow cookers make enough heat to heat the contents of the ceramic pot.
Jan 10, 2010 | CorningWare SC60 Slow Cooker
Royal doulton multi cooker
not a solution as such but u can use it as a slow cooker on low
put it on put veg in add water then meat leave about 1 inch gap from lid and put on low for a few hours dont let it boil dry
Oct 15, 2008 | Crock Pots & Slow Cookers
Cuchen Premium IH Pressure Rice Cooker 6Cup Logo
37 people viewed this question
Top Cuchen Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Cuchen Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
