Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
Tecumseh 12.5 ohv engine decompression valve isnt working. How can I fix it?
2 Suggested Answers
SOURCE: I have a Tecumseh 12.5 hp vertical ohv engine
My 13.5hp ov358ea is .004 both valves. Would like to know model of your engine. I want to replace the non-adjustable carburetor of my 13.5hp ov358ea with an adjustable carburetor.
Retired Airline Mechanic
Posted on Jun 27, 2010
I have a petrol golf cart wont start
Brian, If engine is of overhead valve type and engine turns over with plug out and will not crank when plug in or turns very slow, the problem is probable valve adjustment required or decompression release faulty on cam shaft. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.kohlerengines.com/maintenance/basicTroubleshooting.htm
briggs and stratton ohv hard start crank fix
How the compression release mechanism works on Briggs and Stratton OHV...
HOW TO ADJUST VALVES FIX HARD TO START Lawn Tractor with OHV Briggs Engine...
Aug 16, 2016 | Cars & Trucks
Par car golf cart wont start
Brian, check valves for proper adjustment, if they are OK then problem could be decompression cam/valve faulty. Check the attached links,instruction and guides, Good luck
Aug 16, 2016 | Golf
Sorry on way 1st question went engine has new gas-fuel filter,line carb taken apart cleaned-starter taken apart wheel is engaging sanded and cleaned flywheel-magneto for sparkplug cleaned and working
Either the valves are out adjustment or the decompressor has failed.
Most OHV valves valve clearance open over time causing the decompression system to become in effective; however, the decopressor fails and even properly adjusted valves will still will not decompress the cylinder for starting.
I just repair a B&S 310000 series that had so much compression that the engine would even complete a cycle. After checking the valve adjustment I found that the decompressor on the cam had failed.
May 12, 2015 | Electrical Supplies
Why is my Briggs and Stratton mower dragging? It won't turn over fast enough to start
If it is an OHV engine the valves are needing adjusting normally as the decompression system quits working causing high compression at start-up speed.
Apr 02, 2015 | Garden
Hard hitting on compression stroke when starting
Most Briggs deco vaves are internal and pretty reliable, the valve clearances are very important, if the exhaust valve clerance is too wide the valve lifter will not work, if there is no adjustment yoy would have to fit a new service valve and re do the clerance by removing material from the valve stem
Jan 02, 2014 | Briggs AND Stratton Intek Briggs &...
Have a 12 hp Tecumseh engine that bvackfires with ohv
Your problem could be one of several things.. A bad spark plug, bad gas, failure to lower the idle and let it run a few seconds prior to shutting it off, unadjusted valves, etc.
I'd start with the plug and some fresh gas, then go from there. Always idle the engine down for a few seconds before shutting it off. This allows all the gas in the combustion chamber to be burned up preventing backfire.
Jan 14, 2012 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Tecumseh 16 hp ohv adjustment
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
Jul 03, 2010 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Husqvarna LR130 burnt out starter
it has one but the way to fix it is to adjust the exahust valve thay should know that thats is how to fix that now the reason you cant find any thing on this is becous tecumseh is out of buisness thay have been out since 2008 i hope this helps you if not call me and ill help ya 918-7281822
Mar 06, 2010 | Husqvarna Garden
Tecumseh 17.5 hp ohv engine won't start
check valve clearance. if ok you going have change carb.sometimes i rebuild a carb everthing seam ok but carb wont work right so i have get a new carb and it works fine evertime
Jul 20, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
150 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
