Question about Nikon One Touch Zoom 90S 35mm Point and Shoot Camera
Nikon one touch zoom 90 camera
My camera keeps giving me an error message "E". It was working perfectly until I tried to take the film out to get it developed. I pressed the autowind button however when I opened the back the film still had not wind back all the way. I then took it to Walgreens to get it developed and let them take the film out. He pushed the rewind button and the film did not rewind for him either. He then put it in some sort of box and manual rewind it back. I took out the battery thinking it would correct itself but did not.
I bought this camera at Value Village for $1.99. It came up with an E. I assumed this was an E for empty. I loaded a film and it is fine.
Posted on Aug 20, 2008
How do I get the SDGC 8GB memory card to work for my Nikon s4100 coolpix camera?
You may need to format the card prior to first use. This should be in the menu system somewhere. Your manual should point you in the right direction.
Jan 09, 2016 | Nikon COOLPIX S4100 14 MP Digital Camera...
Where to buy nikon one touch 90s film?
35mm film should still be available at any camera store. Many drugstores and supermarkets also stock film, though not as wide a selection.
Oct 25, 2014 | Nikon One Touch Zoom 90S 35mm Point and...
My polaroid pictures are coming out blank?
I assume they are coming out almost completely white. Here are some guesses based on my experience with 4x5 Polaroid film from decades ago. Things may have changed.
First guess: This type of film has small packets of chemicals that are popped open and spread by rollers in the camera. These chemicals develop the film. If the pinch roller's no longer squeeze tightly enough, the film will come out white. Try googling your camera name and rollers to see if others have this problem.
Second guess: Another possibility is the film was not stored properly or expired. Have you tried replacing the film?
Third guess: Not likely, because I expect this camera is fully automatic, but are you able to adjust shutter speed or aperture? The images may be over exposed if shutter speed is slow. Are there mode settings like A, T and M? If so, put the camera into A mode. When you press the button do you hear a fast and immediate click-click, or do you hear a click followed by another click shortly after?
Mar 29, 2014 | Fujifilm Instax Mini 7S Instant Film...
Two rolls of film developed at CVS - apparently not exposed???
it is not unknown for film developing sites to with hold good photos so take another practice roll and have it developed somewhere else
That will prove either the camera or the developer
Apr 23, 2017 | Pentax K1000 35mm SLR Camera
How do i remove film from nikon lite zoom ed 130
First rewind film in canster then when you hear the click you are finished rewinding the pull up on left winder knob this will open the door keep holing up and let fil drop out walla you're done.
Oct 01, 2013 | Nikon Lite Touch Zoom 130ed 35mm Film...
I need to down load manual for nikon lite touch 120 zoom ed
The closest I could find is the manual for the LiteTouch Zoom 150ED. I believe the biggest difference between the two is the zoom range, so this manual should get you going.
May 12, 2012 | Nikon Lite Touch Zoom 120 ED/QD 35mm Point...
Aug 10, 2011 | Nikon Lite Touch Zoom 120 ED/QD 35mm Point...
I have an old Nikon Lite Touch Zoom 100 AF camera and I am having trouble loading the film. Can you use Kodak Advantix APS film in this camera or should I be using manual loading film instead?
This camera uses 35mm film, not APS film. 35mm is a larger format, giving MUCH better results, at the expense of having to manually pull the leader across to the take-up spool each time you load a roll.
Dec 29, 2010 | Nikon Lite Touch Zoom 120 ED/QD 35mm Point...
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
Nov 03, 2010 | Nikon N80 35mm SLR Camera
I have a fuji A100 10.0 megapixil digital camera. am getting zoom error message and cant get camera to do anything..can you help
Owners manual says "zoom error" indicates a camera malfunction. But, try this, gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur.
Also, sometimes you may have to try several times until you finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Mar 19, 2010 | Fujitsu Cameras
Nikon One Touch Zoom 90S 35mm Point and Shoot Camera Logo
288 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
