Cour wires on old thermostat to new 40120 thermostat
  • 499 Answers
Here you are.
Cour wires on old thermostat to new 40120 - 94fd7bf2-a553-407e-8629-e89b1dae9625.jpg
Posted on Dec 16, 2013
Wiring Honeywell 9580 to old furnace with no C wire
This is not going to be easy. Check the wiring in the wall to look for the third wire. If they did not run one, you have to run new wire to the furnace and thermostat. If they stapled that wire to the walls inside studs, then it is going to be even harder to run the new wire. Once you run that new wire then you have to locate the connection in the furnace that has the common (c) wire for the transformer. Check you tube to see if the have any how to video.
Oct 13, 2015 | Honeywell RTH8580WF WiFi Thermostat
I have replaced the batteries in the thermostat but still not working what do I do the battery light is still on
Go to the manufacturers web site. They should have connections on there either (or both) to download manual, or speak to assistant. They will be able to tell you what to do and your nearest service agent.
Oct 18, 2014 | Dryers
Thermostat wire problem
That's very possible. Maybe when you were pulling it was snagging on something. I would strip the new wire again at the splice and give it another shot. Possibly
May 09, 2017 | Honeywell Programmable Thermostat Heater
Usually there is a blue wire to the thermostat but in this case it is not. instead there is a black wire. i used that one as blue. now there is no heat. it is a hunter cool/ heater unit.
Red Wire Old to
New RC and RH Terminal
Y Old = W ?
New = Y1 Terminal
G should be for the fan Old to
New =Green Terminal
White is for Heat W2 Old to
New =W/B tremnial
X2 Is used only on 24 volt thermostat that need 24 volts to opperate the thermostat usly not used on most thermostat
To start I would not hook this wire to any thing just yet
Tape it so it can not short any thing Black Wire
Orange Old to
New Y/O Not used
Jan 03, 2010 | LG LSC183VMA Split System Air Conditioner
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Wiring in a new thermostat
yes .common as in the netural side of the transformer x to cif not hooked up the stat will still work. and honeywell has good support for their products . Tom
Jun 20, 2009 | Intertherm P3RA-048K Air Conditioner
Old mercury thermostat, New furnace wiring issues
Two wire hookup on the old thermostat tells me that it was set up for heating only. You will most likely need a modern thermostat. But in the meantime try this with the old one. The two red wires on the furnace are probably Rh & Rc. If so these can be put "together" on the R terminal on the old stat. The two W's on the new furnace are probably W1 &v W2 This is for first and second stage heat. You can put the two "together" on the W terminal on the old stat. Do not hook up the greens (blower fan wires). Do not hook up the blue wires (They would go to the Y terminal on a modern stat for airconditioning.
Who ever sold you the furnace should have offered you a new thermostat.
Good luck....
Mar 29, 2009 | Honeywell Programmable Thermostat Heater
Changing out old thermostat
your old thermostat is a milivolt and the wire runs from the heater to the thermostat. You have to open the back of the new one and connect the wire as per the instructions on the wireing diagram that came with the new one. I just installed a similar one myself, you will be very happy with it.
Jan 24, 2009 | Honeywell Electronic Programmable...
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
