Question about Charging & Starting Systems for Dodge Ram SRT-10
Steering wheel stiff
Used car earlier everything is fine. 6 hours later as i was backing up i notice the steering was to hard to turn. checked the steering fluid and was good
  • 2,113 Answers
Either the vacuum to the power steering is not working right or you may need the power steering replaced with a rebuilt one
Posted on Nov 17, 2013
My steering wheel is hard to turn what could that be
Possible causes for a stiff steering wheel are a loose or damaged power steering belt, low power steeringfluid levels, a damaged or leaking power steering rack or a broken power steering pump.
What can cause a steering wheel to be hard to turn? ' Reference.com
https://www.reference.com/.../can-cause-steering-wheel-hard-turn-8b7a03d931c5d8cd steering wheel is hard to turn Google Search
Dec 23, 2016 | Cars & Trucks
Sometimes its hard to turn van
First I'd check your power steering fluid. However it's common for the rack and pinion to go bad as the vehicle ages, other than that it could also be you're power steering pump. You will have to have a mechanic take a look at it to be sure.
Mar 07, 2014 | 2003 Kia Sedona
Chevy Impala leaking steering fluid and steering wheel stiff.
ck. p.s hoses 4 leakage fill pump have someone turn wheel back & forth look 4 leak
Nov 06, 2012 | 2000 Chevrolet Impala
Power steering pump replaced, start to work ok, after 10 milles driving, steering wheel is hard, like pump is not working, under hood everything look ok.
YOU HAVE AIR IN THE POWER STEERING SYSTEM.YOU NEED TO BLEED POWER STEERING PUMP FIRST BEFORE DRIVING VECHICLE.CHECK POWER STEERING FLUID LEVEL ADD MORE POWER STEERING UNTIL REACH FULL COLD MARK..RAISE VECHICLE FRONT WHEELS OFF THE GROUND.START ENGINE LET IT IDLE WHILE TURNING STEERING WHEEL LEFT TO RIGHT NON STOP DONT LOCK OR STOP STEERING WHEEL KEEP TURNING IT SEVERAL TIMES CHECK POWER STEERING FLUID IF LOW ADD UNTIL YOU GET COLD MARK ON DIP STICK DONT OVER FILL POWER STEERING PUMP BLOW A SEAL.IF POWER STEERING FLUID LOOK TAN COLOR SYSTEM FULL OF AIR.TURN OFF IGNITION LET CAR SET FOR A WHILE CHECK FLUID LEVEL.IF STEERING WHEEL FEEL STIFF HARD TURNING DONT DRIVE CAR UNTIL YOU HAVE NORMAL STEERING.IF STILL HAVE AIR IN SYSTEM BLEED SYSTEM UNTIL AIR IS OUT.
Feb 25, 2011 | 2002 Chevrolet Avalanche
The steering is very stiff especially at lower speeds. The steering wheel makes a wine that is barely audible when I'm turning. Just today I started to notice a soft clicking noise when making a hard...
When you put p/w steering fluid in did you notice any leaks on or around p/w steering lines? Have you had to replace the fluid on a regular bases? The clicking noise while turning could be cv axles have you checked them?
Jan 20, 2011 | 2003 Chevrolet Monte Carlo
My power steering resevoir was empty. I noticed it because my steering was suddenly stiff this morning. Nothing in my manual said anything about a particular type of PS fluid so I went to Walmart and...
You will have to look where it is leaking from and get it fixed. Running without power steering fluid will eventually burn you power steering pump out and yes if you power steering is that hard to turn when out of fliud, it is dangerous.
Aug 28, 2010 | 1999 Volkswagen Beetle
Stiff steering wheel upon start up
Check your serpintine belt for cracks, & dryness. Also if wet the steering will not operate easily neither
Mar 18, 2010 | 1995 Pontiac Sunfire
My key wont turn in my 87 nissan pathfinder. the steering wheel is locked but we have tried jiggling the wheel, pressing the break, shifting it out of gear and back, unhooking the battery. the break is...
The key and tumbler is bad. If rocking the steering wheel did not work the tumbler is the problem. Which brake foot or parking brake is stiff ? How do you mean stiff ? Is it hard , or hard to push?
Sep 30, 2009 | 1987 Nissan Pathfinder
Golf 3 gsx no powersteering , steering very stiff
Have you checked the tyre pressures. If you have no power steering a flat tyre will make tunning the wheels hard due to more turnning rsistance. Also a seized ball joint some where would also make steering hard.Hope this helps
Jun 03, 2009 | 1995 Volkswagen Golf
Key will not turn to start vehicle.
Try pushing in the key while turning the wheel either way. And jiggling it. This happens because the steering locks for the car's protection. If we park it with the wheels turned, it locks in that position. If that does not work, you may have to call a good mechanic to help you.
Jan 22, 2009 | 1993 Isuzu Trooper
Charging & Starting Systems for Dodge Ram SRT-10 Logo
106 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Ruben Diaz
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
