Question about Coleman LED CT50 6AA Ultra High Powered Aluminum Flashlight 500
Change bulb batteries - Coleman LED CT50 6AA Ultra High Powered Aluminum Flashlight 500
I changed the front bulbs and now the battery won't hold a charge
Sounds like the battery was on it's way out, time for a new one. Unless there is something wrong with the wiring harness maybe a short! Sounds like it was just your batteries time though. Goo luck!
Mar 31, 2014 | 2004 Honda CBR 125 R
How hard is it to change a fog light bulb on a 2005 Subaru Forester? Can anyone do it?
Front Fog Light Assembly
REMOVAL
  1. Disconnect the ground cable from battery.
105919447
  1. Remove the two clips and lower mudguard on side that bulb is being changed.
  2. Disconnect the harness connector from bulb on back of fog lamp.
105919448
Front Fog Light Bulb
REMOVAL
1. Locate back cover on fog lamp assembly where bulb is located inside.
105919462
  1. Remove the back cover.
105919463
  1. Remove the spring retainer, and then detach the fog light bulb.
  2. DO NOT TOUCH HALOGEN BULB!! Oils from skin will cause bulb to explode during operation.
Jul 27, 2011 | Subaru Forester Cars & Trucks
How do you change a light bulb on the the 95 eagle summit driver side
To replace the right headlight bulb, unbolt the battery hold downs,take off the the positive and negative battery cables, now, lift the battery out of the way. The bulb is held in by a plastic ring. Unscrew the ring (1/3 turn) and wiggle the bulb out of the headlight housing. Now you can get a good enough grip on the bulb to separate it from the three wire plug attaching it to the harness. Take your new bulb out of the package and carefully place it into the headlight housing (BE CAREFUL NOT TO TOUCH THE GLASS OF THE BULB WITH YOUR FINGERS). This will shorten the life of the bulb . Clean it off with a clean drying alcohol. Take the plastic ring and use it to secure the bulb in the headlight housing. Now plug the harness onto the bulb and test that the bulb is working properly (use jumper cables from the battery to the cables. If all is working correctly reinstall the battery in reverse order.
Dec 03, 2010 | 1995 Eagle Summit
Can not get to cover to change light buld battery in the way
You will obviously have to disconnect, and remove the battery,to gain
access to the bulb. I'll warn you straight off, that it is not something a
novice will want to mess with,since messing with the bulb spring will
try the patience of the best. I own an 04' Focus,and it's a complete
nightmare to change the bulbs. Good luck.
Mar 31, 2010 | 2001 Ford Focus
How do I get to the drivers side light bulb in a 2006 Chrysler Sebring Sedan? I have the replacement bulb and want to change it myself.
I will assume you are talking about the headlight?!
Removal
CAUTION: do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced life will result.
1) Disconnect and isolate negative battery cable.
2) Remove headlamp unit retaining screws. (bolts)
3) Remove headlamp unit to expose back of unit.
4) Disconnect wire connector from back of headlamp bulb.
5) Rotate retaining ring counterclockwise.
6) Remove retaining ring.
7) Pull headlamp bulb and remove from headlamp unit.
Installation
1) Install headlamp bulb to the headlamp unit.
2) Install headlamp bulb retaining ring.
3) Rotate retaining ring clockwise.
4) Connect wire connector to bulb.
5) Install headlamp unit.
6) Install headlamp retaining screws. (bolts)
7) Connect the battery negative cable.
More detailed info on how to get unit out.
Removal
1) Disconnect and isolate the battery negative cable.
2) Remove the two retaining screws.
3) Remove the upper fascia retainers by prying under the head of the fasteners with a flat bladed tool.
4) Remove headlamp unit from fender side first, then pull headlamp unit out.
5) Disconnect the wiring harness from the bulbs.
6) Remove the headlamp unit.
Installation
1) Connect wire harness to the bulbs.
2) Install headlamp unit.
3) Install the retaining screws.
4) Install upper fascia retainers.
5) Connect the battery negative cable.
I hope this will help you to get the light changed.
Jan 11, 2010 | 2006 Chrysler Sebring
Headlight change
Please don't forget to rate:
Headlight Removal & Installation Bulb Replacement
  1. Disconnect the negative battery cable.
  2. Disconnect the wiring connector from the back of the bulb.
  3. Remove the rubber cap by pulling.
  4. Squeeze the retainer and remove the headlamp bulb carefully. Do not shake or rotate the bulb when removing it.
To Install:
  1. Install the bulb in the housing and secure with retainer.
  2. Install the rubber cap.
  3. Connect the electrical connector to the bulb.
  4. Connect the negative battery cable.
Jul 22, 2009 | 2004 Infiniti QX4
Change right front turn signal bulb
im not positive but it looks very similar to my moms 2006 honda accord which goes through bulbs like there nothing...on her car in order to change the bulbs you actually have to pop the hood and look down towards the light and you can see the bulb make sure that you take out the blinker bulb and not the low beam bulb also if it is on the right side you may have to remove the battery to see the bulb so look on the left side first and if you can see the bulbs then you will know if you need to take the battery out or not
May 15, 2009 | 2003 Kia Optima
How do you change the headlight bulb on a 1996 lexus ls 400
I can't tell you exactly how to do it on a lexus but generally bulbs are changed from the rear of the assembly inside the engine compartment. you may have to remove the battery if it is on that side. do not touch the bulb with your fingers as that will shorten it's lifespan.
Apr 08, 2009 | 1990 Lexus LS 400
I need to change the headlamp bulb.
  1. Disconnect and isolate the battery negative cable.
  2. Remove screws attaching headlamp module to upper crossmember.
  3. Remove headlamp module from vehicle.
  4. Disconnect wire connector from back of headlamp.
  5. Remove bulb from headlamp unit.
INSTALLATION
CAUTION: Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
  1. Connect wire connectors to the back of headlamp module.
  2. Place headlamp module in position.
  3. Install screws attaching headlamp module to upper crossmember.
  4. Connect battery negative cable.
Mar 21, 2009 | 2003 Dodge SRT-4
Coleman LED CT50 6AA Ultra High Powered Aluminum Flashlight 500 Logo
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
