Question about NuTone 65103 Exhaust Heater Vent Fan Motor For Nutone 57768 63675000
Install HPM R622D2 - NuTone 65103 Exhaust Heater Vent Fan Motor For Nutone 57768 63675000
How do I set a 24 hour timer D809/1
HPM 24 hour timer instructions: rotate dial clockwise until current time lines up with pointer located on inner dial. There are segments located around edge of dial. Pull up these segments to set on-off times. Turn Load switch ON. Plug Load into timer. Plug timer into receptacle. Manually rotate dial clockwise and observe Load turning ON-OFF. This will show if timer is ON or OFF when segments are pulled up.
I think the D809/1 has 15 minute intervals. The only manual on the HPM site for a 24 hour timer close to this is:
https://hpm.com.au/app/document/asset/23/16/6/d8180d-hpm-24hr-outdoor-timer-instruction-sheet.pdf
Sold at Bunnings in Australia, you might find a manual with one! Alternatively, here is another place they are sold and given they are inexpensive, it might be worth it to just get the instructions. Amazingly, if you try to search for a manual for this, you can not find it. You just get comments like the techs were not help, the manual was in Chinese, and after translation, were not even understood by the techs. Heaven knows what the truth is. The HPM manual above is clearly in English. Note the device manual above likely is set for half hour intervals. Good luck.
http://www.radioparts.com.au/ProductDisplay.aspx?popup=1&Category=SXKK1045&Product=49161200&ProdDesc=D809%2F1+24+HOUR+ANALOGUE+TIMER+HPM
Aug 11, 2017 | Hardware & Accessories
Instructions to operate hpm d817 dusk
1) Copy following link to identify timer and download instructions for D817DUSK timer from Legrand-HPM:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
2) Add comment and include photo of timer
Dec 11, 2012 | Hardware & Accessories
HPM D817/2 electronic timer 7 face buttons, Manual required. Thanks
1) I have located a similar timer, with similar buttons.
Tork 451D with manual:
The buttons are in different order, and Tork is 120Volt timer, not 240Volt like HPM.
This information may help if you have HPM timer and can experiment.
I doubt this information will help if you are simply looking for a clear cut 1:1 manual to sell on-line.
2) The HPM timer does not sell in US, but the timer is inexpensive and you can purchase the timer for $27 and scan manual into pdf format.
3) HPM also has a contact us page, but I don't know if they will send manual of if link is good:
http://www.hpm.com.au/Products.aspx?pid=18#Timers/Timers/7-Day-Timers
Dec 26, 2010 | Hardware & Accessories
Instructions to set a hpm digital timer
http://truthseekernz.blogspot.com/2009/04/hpm-digital-electronic-timer.html
Jul 29, 2010 | Vacuums
Dosent stay connected
I also have this problem with my c903
Jan 16, 2010 | Sony Ericsson Stereo Portable Handsfree...
Sony HPM-70 not working with music feature on phone
I got a "failed" when I tried to listen to my playlist, on the first song. I switched to a different song lower down the list, and then it worked. Not sure what made the difference.
Feb 06, 2009 | Sony HPM-70 Headset
SONY ERICSSON HPM-85
i have a w595 and hpm 85, its connection is loose when i connect it if the port moves the handsfree logo dissapears
Jun 17, 2008 | Sony Ericsson HPM-85 Consumer Headphones
NuTone 65103 Exhaust Heater Vent Fan Motor For Nutone 57768 63675000 Logo
76 people viewed this question
Top NuTone Plumbing Experts
Paul Carew
Tom Chichester
Are you a NuTone Plumbing Expert? Answer questions, earn points and help others
