Question about Trend Micro PC-cillin Internet Security 2005 for PC
Pc-cillin 2007 internet security problem
#1 There is a window that keeps popping up and telling me to reinstall Trend micro because of an some failure. I did uninstall and reinstall from the trendmicro.com website and it still is showing that window. #2 It keeps opening another popup that shows me other computers/ip addresses connected to my wireless even the default ip 192.168.1.1. How do I stop this? I don't want anyone other then me connect to my wireless. I went to my network connections and made changes but still not help.
  • 661 Answers
In order to prevent access to your wireless router, log on to your router and setup a WEP key under wireless security. (your Wireless router's setup guide should tell you how to do this) don't forget to print this key as you will need to input it into any device you wish to Authorize to use your wireless network. Re: Pc-cillin, try looking on the manufacturer's website for a patch to solve this issue, or a removal tool to give you a clean start.
Posted on Oct 07, 2007
SOURCE:
Unable to remove 2005 trend micro ,error message says type in password,how do delete and perhaps upgrade to the latest version?
Using the PCCTool To uninstall the program using the Support Tool, follow the steps below: 1. Go to the C:\Program Files\Trend Micro\Internet Security 2005\ directory. 2. Double-click on the PCCTool.exe file to start it up. 3. When the Trend Micro PC-cillin Internet Security window appears, go to the [E] Uninstall tab. 4. When you see the confirmation dialog box, click Uninstall. 5. Wait while the program is completely removed from your system.
6. When the uninstallation finishes and you see a dialog box asking you whether you want to restart now or later, click Yes to restart your computer and have the changes take effect immediately or No to restart and have the changes take effect at a later time.
Oct 24, 2010 | Trend Micro PC-cillin Internet Security...
PC-cillin icon is stuck 'loading',
Hi
you may remove or uninstall the program and install and new one, don't over write the installation.
Oct 09, 2009 | Trend Micro PC-cillin Internet Security...
Trend micro internet security.the firewall keeps on shutting down
remove TMI through this
http://esupport.trendmicro.com/Pages/How-do-I-remove-old-or-new-versions-of-Trend-Micro-products-in-my-comp.aspx
and then D/L it again
Apr 12, 2009 | Trend Micro PC-cillin Internet Security...
Trend micro will not load
If the issue still occurs, restart PC-cillin Internet Security using PCCTool:
a.
Double-click My Computer on your Desktop.
b.
Double-click Local Disk.
c.
d.
Double-click the PCCTool.exe file (its icon appears as a capsule and a lifesaver).
e.
On the General tab, under Start and Stop, click 2. Quit All Modules.
f.
Click 1. Start All Modules.
g.
Check if the issue still occurs.
Jan 22, 2009 | Trend Micro PC-cillin Internet Security...
No updates
updating might help, use the same serial number and create a new account info (for 2007 version and below) when prompted.
http://esupport.trendmicro.com/Pages/Where-can-I-download-the-installer-file-for-my-Trend-Micro-Consumer-pr.aspx
Jan 20, 2009 | Trend Micro PC-cillin Internet Security...
Cannot update trend micro
Reinstall last Windows service pack again
Roboot
Done!
Jan 18, 2009 | Trend Micro PC-cillin Internet Security...
Trend micro internet security 2008
Dear Sir/Madam,
This error will appear if you have installed the 16.05 version of
Trend Micro Internet Security Pro, Trend Micro Internet Security and
Trend Micro AntiVirus plus AntiSpyware 2008 on a computer running
Windows Vista with Service Pack 1 or Window XP with Service Pack 3.
The Trend Micro Personal Firewall and the Unauthorized Changes
Prevention features main components do not work with the new service
packs from Microsoft.
A working version of Trend Micro Internet Security Pro, Trend Micro
Internet Security and Trend Micro AntiVirus plus AntiSpyware 2008 with
Windows Vista SP1 and Windows XP SP3 would be released sometime in
February 2008.
The release would be timed before Microsoft uploads the new service
packs in their automatic update servers for Windows.
To prevent this message from appearing, follow the steps indicated
below:
a.Check the program version of the Trend Micro program installed on
your computer.
b.If you are using version 16.05 and you want to continue using this
latest version of the Trend Micro program, you must uninstall the non-
working service pack from Microsoft.
c. If you do not want to remove the new Microsoft service packs, Trend
Micro suggests that you uninstall the Trend Micro program installed in
your computer and install PC-cillin Internet Security 2007 until the
release of the working version.
Thanks
Good Luck
“Don’t Forget to rate the Solution”
Jun 06, 2008 | Trend Micro PC-cillin Internet Security...
Trend Micro PC-cillin Internet Security 14 loading but never loaded
I had a similar problem and this worked for me
with Trend Micros Internet Security.
You will have to uninstall the program first then reinstall it, otherwise it
will hang and cause problems with your computer.
In order to uninstall it do these steps.
Go to Control Panel > Administrative Tools > System Configuation.
Makes sure you select Selective Startup, and that Load Startup Items is unchecked.
Click OK, and you should be prompted to reboot.
After you reboot and the system is loaded your Virus Software icon will NOT
be in the taskbar trying to load.
Now go into control panel > Programs and Features.
Find the virus program, hightlight and select the uninstall option.
After its done doing that go back into the Control Panel >
Administrative Tools > System Configuration. Select Normal Startup
and hit the OK button.
Reboot again when you see the button prompt.
Now, after the system comes up, reinstall your virus software,
You should be good to go from there.
The process is for Vista, but if your running Windows XP it is very similar.
Apr 14, 2008 | Trend Micro PC-cillin Internet Security...
2008 Trend Micro Internet Security not compatable to Windows Vista SP1 and Windows XP SP3.
I suggest you to use NORTON 360. this product is so cool.
enhanced antivirus
online fraud protection
automated storage and retrieval
clean up and defragmentation
just like a all in one package from symantec.
i can help you with this product if you have problems
Jan 28, 2008 | Trend Micro PC-cillin Internet Security...
Problem With Trend micro Pc Cillin internet security 2007
i am sure -----u have a virus.
emidatly.scan and find out virus & nutrelise it...
then get u r fire wall on..& try to connect to net again man...
best regards & best of luck..
Oct 10, 2007 | Trend Micro PC-cillin Internet Security...
Trend Micro PC-cillin Internet Security 2005 for PC Logo
54 people viewed this question
Top Trend Micro Computers & Internet Experts
Peter Dragonetti
Scoee Scoffer
Dalynn Turner
Are you a Trend Micro Computer and Internet Expert? Answer questions, earn points and help others
