Initial plug in..flashing F2..P85KQA..
Electric Blanket control #P85KQA F2 flashing in control does not stop until unplugged. Brand New.. SunBeam
SOURCE: My Sunbeam electric blanket controls
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Posted on Dec 22, 2008
  • 1796 Answers
SOURCE: My queen size electric blanket...
Hi!!
Here is some of the frecuent questions regarding "F" flashing on the Temp. Controls. Clicking on the following link will take you to the Owners Manual Page for Sunbeam Electric Blankets.
If you need additional info. post a comment. Good Luck!
http://www.sunbeam.com/manuals/SunbeamBedding/7Ctrl_Man.pdf
Q What does “FF” mean on my Electronic Digital Control?
A
The digital controls are designed to notify you in the event that a problem has been
discovered by flashing “FF” on the display. Follow instructions on the flag tag to reset
control. First, check the blanket/mattress pad for visual damage. If no visual damage is
found, unplug the system from wall outlet. Check that the control is well
connected to the module. Plug the power cord into the wall outlet. Set the
control to “On.” If the system still does not operate after 2 or 3 times
trying to reset, disconnect the power cord and contact Sunbeam Consumer
Care.
Q What does a flashing light mean on my EasySet™, SlimStyle™ AO or
SlimStyle™ control ?
A
These controls are designed to notify you in the event that a problem has
been discovered by flashing the light on the control. Follow instructions on
the flag tag to reset control. First, check the warming product for visual damage. If no
visual damage is found, unplug the system from wall outlet. Check that the control is well
connected to the module. Plug the power cord into the wall outlet and turn the control On.
If the product still does not operate after 2 or 3 times trying to reset, disconnect the power
cord and contact Sunbeam Consumer Care.
Posted on Sep 03, 2010
SOURCE: sunbeam electric blanket flashing ff
Ok folks. I fixed it. I unplugged and then waited and replugged and started at high or 9 and then it went to FF in 60minutes or a couple of minutes. I scratched my head and tried this fix--instead of starting again at 9 or H I started at level 7. That did it. FF most probably indicates excess current, and the H or 9 probably is too high to set. So unplug -repluf-turn on and dial 7 or lower. It should fix it. Or buy a new one.
Posted on Nov 21, 2010
hvac1960
  • 2133 Answers
SOURCE: Electric blanket won't stop flashing
FF- loose contacts wiring. check all fuses and also wiring to your unit.
Posted on Dec 26, 2010
  • 133 Answers
SOURCE: I bought a Sunbeam electric
The only thing you can do, other than pull all the wire out to test it, is check the temperature control. If you have another you know works or can borrow one to test the blanket, that's the easiest. Else, you will need to use a "Glow Stick". A Glow Stick is an electrical tester that does not require physical contact with a bear conductor to detect voltage. They are available at Hard Ware stores, Menard's, Home Depot, etc. Plug the blanket controller into the wall outlet and touch the 2 wires near the thermostat. If it glows, the cord is good and the outlet has power. Now test the wires coming out of the thermostat that go to the blanket. Turn the thermostat way up and down and see if the light glows. If no, the thermostat is bad. If it glows, indicating power has made it through the thermostat, continue to test along those wires to the blanket. If you have power at the plug on the blanket, continue onto the blanket along the wires that provide the heat. The light will continue to glow on-till you get to the break in the line. When the light goes out, that's the break point. If you do find a break in the blanket and would like me to walk through the repair, I will be happy to. The Glow Stick is a good investment for safely testing anything electrical without the risk of being shocked. Please rate this for me. I am new to the site and need to improve on writing what I am thinking. Let me know how it goes for you, OK?
Roger
Posted on Apr 02, 2011
Fix flashing f2
Unplug it, and wait 15 minutes. Then plug it back in. It should come on L. Let it sit another 15-20 minutes. You should be able to turn it up after that.
Mar 05, 2015 | Sunbeam Electric Blanket - queen
The 2 controls to our electric blanket are flashing "FF". What does that mean, plus there's no heat at all from it.
With the Sunbeam blankets that I have owned, FF meant that there was a bad connection somewhere. Have you tried the unplugging and replugging the Controller cord back into the blanket? Make sure it is plugged in GOOD AND TIGHT. If that part is connected as tightly as it can go, you may have a defective element.
Dec 18, 2014 | Sunbeam Pac 259 Dual Electric Blanket...
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
Se My blanket is blinking F2 and I can't set the controls
To reset the control:
1) Unplug the blanket from the wall outlet.
2) Check that the control is well connected to the module. (Disconnect and re-connect it).
3) Plug the power cord into the wall outlet.
4) Set the control to "on".
Try 1-4 three times. If the blanket still does not operate, disconnect the power cord and contact Sunbeam Customer Care at 1-(800) 892-7684.
Oct 07, 2014 | Sunbeam Electric Blanket - queen
My husband and i were just recently given the queen size, dual remote heating blanket from you guys. When we try to turn on either of our remotes, it flashes F2 consistently unless unplugged. Is there...
The first link has some info about the F2 code.Apparently it used to be seen as FF but was changed.It is a power problem.It is still the same problem,which is REALLY not good.The next couple of links are forums which people also have the same problem as you.I would seriously get rid of that blanket.I saw someone mention EMF.I know exactly what EMF is and it is not an issue with this blanket at all,and is present in many things.A microwave probably has more,and still is not an issue.Anything that plugs into a wall has some form of EMF present,so do not even worry about it.
http://wiki.answers.com/Q/What_does_the_flashing_code_F2_mean_on_the_Sunbeam_Dual_Electric_Blanket
http://www.consumeraffairs.com/homeowners/sunbeam.html
http://www.complaintsboard.com/complaints/sunbeam-westpointe-amp-jc-penny039s-electric-blanket-c40368.html
http://www.complaintsboard.com/complaints/sunbeam-heating-blanket-c134216.html
Nov 28, 2010 | Sunbeam Heating & Cooling
My dual control sunbeam electric blanket flashes on one side
Return this product as it is a fire hazard.
please mark this as a fixya! thanks
Feb 22, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
F2 Fault Code On Heating Pad
I am trying something now as I was told F2 requires you to check the blanket for wear and tear and plug it back in. 3 times doing this should be sufficient. If it still reads F2 it's "gone" Ours is new so it shouldn't be "gone" but here's what I found...Where the plug goes into the blanket there are 4 holes for 4 silver pins. I noticed the 3rd pin was a bit lower than the other 3. It will not move up with pliers so don't force it just return it. check there
Jan 10, 2009 | Sunbeam 722 Auto Shut-Off Heating Pad...
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
My Sunbeam electric blanket controls blink when I plug the control cable into the blanket. I cannot turn the controls on or off.
Jul 21, 2008 | Heating & Cooling
Electric blanket error code
My new blanket works great. Then I changed my sheets and would get the F2 problem. Very consistent after 5 tries with F2 blinking by unplugging at wall outlet and comes on with F2 blinking. Let it rest a night and still the same.
Then I unplug it at the blanket. Hmm, notice a pin was lower than the others. PUSH BACK IN FIRM and tried again. Perfect.
Mar 25, 2008 | Heating & Cooling
Heating & Cooling Logo
214 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
