Question about Frigidaire Gallery Series FGHD2465NF
Fghd465NF frigidaire dishwasher uo error message.
The dishwasher fills for about 10 seconds with a heartbeat like soft clicking noise, then stops and flashes er---uo error message. I called Frigidaire this morning and they said it was the vent and the clicking noise was a different problem in the control panel.
SOURCE: Er message on panel of Frigidaire GLD3450RD
I had the same problem last spring. Unfortnuatly, the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes. For me, it meant a new electronic module.
If the eletronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Posted on Jan 03, 2008
SOURCE: Error Message 'Er' on frigidaire dishwasher
I had the same problem. I pressed the "Start Cancel" button, kept it down, then pressed "Rinse Only" button. The display then went clear. I pressed "Start Cancel" again, then "83" showed up on the display. I let it run its cycle, then it corrected itself. A little scary, but it worked. This answer board is great!
Posted on Feb 22, 2009
SOURCE: 6 mo. old frigidaire d/w displays the "ER clean S" flashing error
Probably a control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
Posted on Apr 08, 2009
  • 19 Answers
SOURCE: Error code ER then UO any ideas?
uo means that the vent isnt closed
Posted on Apr 29, 2009
So far so good. I fixed mine by removing the vent and even though it says no repairable parts I disassembled it then removed the rubber gasket and cleaned it with a brush under hot water. I then cleaned the plastic ring it seals against. Next I removed the spring and stretched it to make it about a quarter inch longer and then reinstalled the spring then the rubber gasket and then closed up the unit. So far it is working fine. I suspect the real problem is that there is a tiny sensor that needs to be covered when the vent is closed. If this is not covered the uo error code is generated.
Posted on Aug 22, 2009
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
Have an FO error on frigidaire dishwasher. anyone knows what this error means?
Hello Ermellina, thank you for your post!
If you are getting an error code "F0" on your Frigidaire dishwasher, it usually means that you are experiencing an issue with the water level. To clear the error code, you can reset your dishwasher. However, since you have already turned off the circuit breaker, at this point, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis. Best - Z
Sep 14, 2014 | Frigidaire Dishwashers
What does the Frididaire dishwasher error code uo mean?
Good Morning Friend, this is Z. Thank you for your question!
Error code UO commonly means that the vent is in an open position. While your Frigidaire dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly.
Before reaching out to a professional, let's try resetting your dishwasher. This can be done by flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your dishwasher. This often clears most false-error codes. If resetting the power does not correct the issue, a professional will need to check the wiring between the vent assembly and main control board.
Best of luck!
Jul 07, 2014 | Frigidaire Dishwashers
Frigidaire 24 in. FDB4315LFC3 STAINLESS STEEL ERROR CODE UO
Hi Mark, thank you for your post!
Before reaching out to a professional, let's try resetting your dishwasher. This can be done by flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn your dishwasher on. This often clears most false-error codes. If resetting the power does not correct the issue, a professional will need to check the wiring between the vent assembly and main control board.
Best of luck!
Jan 18, 2014 | Frigidaire 24 in. PLD3465REC Stainless...
Message "er" and "uo" on front panel and slight bumping noise
The UO code on most Frigidaire dishwashers means that the vent at the back of the dishwasher is open (or at least the sensor is claiming it is open). Since this vent should be closed except during the drying cycle, the unit will not start. This avoids having the washer spray water into your cabinet during the wash cycle.
The vent sensor is an optical sensor that is inside the vent assembly. So there are a few places that could fail causing the error. First check the wiring and the connectors for the wires between the vent and the CCU (main control board). If there are any broken wires or corrosion the message may not be reaching the control board. Replace any faulty wiring. If the wiring is fine, try replacing the vent assembly. On some Frigidaire models, the wiring and the vent assembly need to be replaced at the same time. If that doesn't solve the problem then the control board needs to be replaced.
Please note: when I look at the parts for the FDB1050REC0, I found a static dryer vent, http://www.appliancepartspros.com/frigidaire-static-dry-vent-154433001-ap3214620.html . Please make sure that you are buying the parts for the correct model dishwasher.
I hope this helps.
Dec 17, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire dishwasher error code
Hello Teresa Ann - Typically error code UO indicates that while the dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly and that the vent plunger is in a closed position. A professional will need to check the wiring between both parts and depending from the results either part may need replacing.
Jan 19, 2013 | Frigidaire Dishwashers
Frigidaire dish washer FDB4315LFo Error code uo
You are experiencing a vent issue - While in wash cycle, Main Control Board does not receive signal from vent assembly that vent plunger is closed. Plunger status is sensed with optical sensor in vent assembly. Check wiring between vent assembly and Main Control Board. If wiring correct, replace vent assembly. If error still exist, replace Main Control Board.
Sep 04, 2012 | Frigidaire Dishwashers
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Apr 22, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire Gallery Series FGHD2465NF Logo
19 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
