Megmeet MIP320FL-2 Sceptre 32" flatscreen sound but no picture on any inputs and TV new out of box
SOURCE: HD Cable Box; HD Plasma...........no picture or sound
Same problem, 42" lg plasma
Posted on Apr 30, 2008
ssforest
  • 11 Answers
SOURCE: scepter 32 tv
You have to get this thing called the backlight inverter from the manufacturer. They'll fix their defective out-of-warranty TV for $250 or you might find the inverter on eBay for $175. I wouldn't trust a used inverter, since it's likely to have the same common problem. Sceptor will warranty their repair, so unless you know what you're doing, you might waste $175 and a lot of work, when you could just spend $250 (plus shipping?) for the whole tv to be "refurbished" with a new warranty.
Posted on Apr 28, 2009
  • 10 Answers
SOURCE: Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
Posted on Aug 09, 2009
dave1645
  • 834 Answers
SOURCE: Westinghouse TV no picture just sound. 32
one or 2 caps in the power supply they will be domed from venting
Posted on Sep 16, 2009
SOURCE: Sceptre 32 tv won't turn off or change channels,
I have the same problem, did you ever get this fixed?
Posted on Feb 17, 2010
Sceptre 32 inch, Blue LED light comes on but no picture or sound.
The internal power supply is failing. You are having to "shock" it into operation by plugging and unplugging.
Jan 01, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
How can i get sound on my computer from Sceptre flatscreen tv
If your Sceptre TV has audio output connections (often RCA connectors), you need an adapter cable with RCA plugs on one end and a miniature stereo plug on the other to connect to lhe LINE IN input of your computer's sound card
Aug 11, 2013 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre tv, no sound no picture
In other-words it is dead. Check its main power regulator board. Replace it.
Jan 09, 2013 | Sceptre 32 X320BVHD 32 LCD TV
SCEPTRE X320BV i HAVE PICTURE ON YpbPR BUT NO SOUND/I HAVE SOUND IF IT'S TURNED ON AV
Connect the same input device to some other TV and check. Connect some other device with composite connections and check the TV.
Aug 06, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
Sceptre tv: no sound but i have picture
Please check whether sound is coming to headphone. If yes, there is some lose contact in the board. If no, try another input device that you are sure works well. If problem persists, please refer it to a qualified service technician.
Jul 29, 2012 | Sceptre 32 X320BVHD 32 LCD TV
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Mar 11, 2012 | Sceptre 32 X320BVHD 32 LCD TV
Televison & Video Logo
350 people viewed this question
Top Televison & Video Experts
Electro Med Services...
