Question about Cadence TXA 3004 4 Channel High Power Amplifier Car Audio Amplifier
Manual the amplifier stop to working after a few minutes
Why does the amp stop working while playing?
If this is an amplifier, you have a bad component that is most likely a capacitor.
Aug 07, 2015 | Audio Players & Recorders
Suddenly stops working and have to wait for a few minutes for it to work again.
Probably a component in the power supply is overheating, You need to take it to the repair shop.
Apr 26, 2015 | Behringer Ultratone K3000fx 300w Keyboard...
Carver pm1400 quits working on right channel from time to time.
suggest you look for dry joints around the faulty channel
Feb 08, 2010 | Carver PM950 Amplifier
Subwoofers stop working after few seconds
Check the subs wiring... follow the manual....
Jul 16, 2009 | Car Audio & Video
My NAD M3 amplifier stops working abruptly.
If NAD doesnt respond , find a decent amp/stereo tech in your area.
I can suggest some depending on where you are.
There's most likely a component failure that regular folks wont be able to fix
Dec 21, 2008 | Audio Players & Recorders
Protection light won't stop blinking/ Subs don't work
The amp probably has shorted output transistors to eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 07, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Speakers cut out after about 10 minutes.
Does the system perform normally- as long as it works? If yes, then the Amplifier is at fault. It cannot be the output Transistors or IC, as the sound is coming from both channels. If you know solid state servicing, I advice replacing all the electrolytic capacitors in the Output stages of the Amplifier. Over a period of time these El Caps dry out, and cause headaches.
Oct 03, 2006 | Technics SCEH790 CD Shelf System
Cadence TXA 3004 4 Channel High Power Amplifier Car Audio Amplifier Logo
23 people viewed this question
Top Cadence Car Audio & Video Experts
xxxxxx xxx
Are you a Cadence Car Audio and Video Expert? Answer questions, earn points and help others
