Question about Sierra Print Artist Platinum
Printartist windows - Sierra Print Artist Platinum
Sir pl tl me that whch antivirus is suitable for window 8
Windows 8 includes an automatically loaded updated version of Windows Defender
which is a full antivirus based on Microsoft Security Essentials.
(Windows Defender
for XP, Vista, and Windows 7 was only antispyware.)
So if you upgrade the protection
is automatic and is on by default at installation.
Windows Defender and Windows SmartScreen fight viruses and other malware
http://windows.microsoft.com/en-US/windows-8/windows-defender#1TC=t1
How to Create a "Windows Defender" Shortcut in Windows 8
http://www.eightforums.com/tutorials/6862-windows-defender-create-shortcut-windows-8-a.html
How to Add a "Windows Defender" Cascading Desktop Context Menu in Windows 8
http://www.eightforums.com/tutorials/8450-windows-defender-cascading-desktop-context-menu-create-windows-8-a.html
Jun 24, 2013 | Acer Aspire Computers & Internet
Printartist login
Greetings,
What is the exact error message ?
Look for other links/shortcut from the Start Menu list (something like Activate)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 20, 2008 | Computers & Internet
Tip
Windows Shortcut Keys
<ol> <li>Windows: Display the Start menu</li> <li>Windows + D: Minimize or restore all windows</li> <li>Windows + E: Display Windows Explorer</li> <li>Windows + F: Display Search for files</li> <li>Windows + Ctrl + F: Display Search for computer</li> <li>Windows + F1: Display Help and Support Center</li> <li>Windows + R: Display Run dialog box</li> <li>Windows + break: Display System Properties dialog box</li> <li>Windows + shift + M: Undo minimize all windows</li> <li>Windows + L: Lock the workstation</li> <li>Windows + U: Open Utility Manager</li> <li>Windows + Q: Quick switching of users (Powertoys only)</li> <li>Windows + Q: Hold Windows Key, then tap Q to scroll thru the different users on your PC</li></ol>
on Dec 27, 2010 | Computers & Internet
Tip
Don't Ignore the Windows Logo Key
The Windows logo key, located in the bottom row of most computer keyboards is a little-used treasure. Don't ignore it. It is the shortcut anchor for the following commands: Windows: Display the Start menu Windows + D: Minimize or restore all windows Windows + E: Display Windows Explorer Windows + F: Display Search for files Windows + Ctrl + F: Display Search for computer Windows + F1: Display Help and Support Center Windows + R: Display Run dialog box Windows + break: Display System Properties dialog box Windows + shift + M: Undo minimize all windows Windows + L: Lock the workstation Windows + U: Open Utility Manager
on Dec 15, 2009 | Computers & Internet
WILL F5D7000AK SUPPORT WINDOWS 7
Windows 2000 Windows 95/98 Windows Me Windows XP Windows 2000 Windows 95/98 Windows Me Windows XP Windows 2000 Windows 95/98 Windows Me Windows XP Windows 2000 Windows 95/98 Windows Me Windows XP
Windows 2000 Windows 95/98 Windows Me Windows XP Windows 2000 Windows 95/98 Windows Me Windows XP Windows 2000 Windows 95/98 Windows Me Windows XP Windows 2000 Windows 95/98 Windows Me Windows XP Windows 2000 Windows 95/98 Windows Me Windows XP
No
It support windows 2000/95/98/ME/xp
Aug 14, 2010 | Belkin 802.11g Wireless Desktop Network...
My favourite programme - Print Artist 4 which has worked with all my computers up to and including XP will not work with Windows 7 - what can I do?
It means that this application is not compatible with Vista or Windows 7. If you have Windows 7 Pro or Ultimate, all you have to do is run the app in XP mode, which is really running an XP virtual machine inside of Windows 7. Just look in Windows help for instructions on how to do it. If you have Home Premium or less, they do not have XP mode. Instead you can download Virtual PC 2007 SP1 from the Microsoft web site for free, install it, then create a virtual machine that uses XP. You will have to have a licensed copy of XP to install on the virtual machine. Then install PrintArtist on the virtual machine and you are ready to go. You can use the virtual machine and Windows 7 on the host system simultaneously and can even exchange data between the two.
Feb 11, 2010 | Computers & Internet
Had to redo computer and reinstall. PA 4. won't install.
I found a solution for installing Sierra Print Artist 4 on XP at this site
http://forum.oldversion.com/programs-support/5831-printartist-4-a.html I did it, works great!
Posting below, thanks to izzy_eckerslike :
"""There is a way to force your computer to load print artist 4
Click on display /settings & reduce colour quality to 16 bit & reduce your screen resolution to 800X600
Then insert the Printartist disk & select install, as before you will see the Sierra logo on your taskbar but it won't move or do anything.
Now put your screen settings back the way they were before & you should see the install screen jump off the taskbar so you can access it.
It will test your computer & tell you it fails as it can't recognise newer technology but ignore that & select 'install anyway' & all should be working"""
Jun 30, 2009 | Sierra Print Artist Platinum
Printartist installation
what does the error clip say
Boot Up error message
I have the same problem. I emailed Nova support and the first reply had a link to Dotnetfx3.0. He said install that and it would fix the problem. I'm running Vista and I discovered after trying to install this version of Dotnet framework, that 3.0 is already integrated into Vista. They should have known that because I told them what platform I was using in my original support request. The next suggestion was to install dotnetfx3.5 which I did along with it's service pack to no avail!! I really don't think their support staff is too computer savy! Their last response when I told them that didn't work either was pretty much "sorry". Anyway, I haven't given up and am concentrating on the dotnet connection. I'll post here if I happen upon a solution.
Jun 15, 2008 | Nova Development Print Artist Version 22...
SamsungX05 ınternet problem
Windows XP Latest Drivers Windows XP Previous Drivers Windows 2000 Drivers
May 15, 2008 | Samsung X05 Notebook
Sierra Print Artist Platinum  Logo
13 people viewed this question
Top Sierra Computers & Internet Experts
Glenn
Glenn
Jacqueline
Are you a Sierra Computer and Internet Expert? Answer questions, earn points and help others
