Question about Ovens
Bosch wall oven
Cooling fan did not come on when i started the oven. it got to temp then i turned it off. that was about 5 minutes ago. now the fan just came on. should i not use the oven?
BingoDabbers
  • 102 Answers
SOURCE: Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Posted on Oct 06, 2007
SOURCE: Bosch HBN 455 Oven Cooling-Fan Issue
Our HBN655 had similar issues- the upper cooling fan would cycle on and off on a relatively quick duty cycle until the whole mess cooled off enough and it shut off.
My workaround is to turn the temperature dial off but leave the oven function dial on to BAKE. This seems to force the fan to stay on; then we shut it off a while later and avoid the annoying fan cycling.
(note- 2 years ago, our fan became intermittent, varying speed, etc... for about 2 months before it quit entirely. When that happened, the oven started to heat then the thermal cutout kicked in and the oven shut down entirely. We ended up replacing the fan and that fixed the bug... except now it's starting to act up again...)
(also note- the racks on this beast have a faulty design. if you have a heavy casserole and slide the rack out all the way, it tends push the sidewalls apart and the rack drops. I spoke with Bosch about this and they sent me new racks, no charge... so they know there's a problem. But the new racks don't fix the bug; they just make it harder to reproduce. I have actually had one rack fall with 2 piping hot casseroles on it. Fortunately no one was hurt.)
Posted on Nov 04, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    eagle338
    • 4889 Answers
    SOURCE: F2 fault, continuous fan after clean cycle for Jenn-Air electric convection wall oven
    The "F2" means the oven control senses runaway temperature. The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
    PS:please disconnect your oven from power supply completely before continuing.
    Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
    If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
    If the reading is still wrong - replace the oven sensor.
    If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
    If there is nothing wrong then the power relay board has to be replaced.
    Posted on Nov 07, 2008
    barkencoa
    • 3463 Answers
    SOURCE: bosch convection double oven,ovens won't heat,only broilers work
    If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
    Plz rate my\solution.
    Thanks.
    Posted on Dec 17, 2008
    Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
    The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
    Oct 16, 2017 | Bosch Ovens
    Why wont fan turn off after use in oven bosch model hbn 13n5,1b
    It should turn off after a while. The fan is actually the cooling of the case, it runs longer if I have used a higher temp setting. If it does not stop after app. 20 min something is broken.
    Sep 03, 2014 | Bosch Ovens
    The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
    Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
    Hope this helps.
    Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
    The fan copntinues to run after oven is turned off
    Most electric ovens have 2 fans. One is a fan forced fan at the back of the oven cavity that you can generally see spinning when the oven/fan forced option is selected. The other is a cavity fan which is situated between the outer skin of the oven and the oven itself. There are generally located at the top of the oven. Because the oven is a wall oven that sits in a tight cavity it cannot cool down easily. The job of the cavity fan is to cool this cavity down by blowing the hot air in the cavity out a small hole, normally in the front of the oven. When you turn the oven off this fan might operate for 5 to 10 minutes until the oven cavity cools sufficiently. If there was no cavity fan the oven and/or cupboard would overheat.
    Feb 06, 2011 | Viking Designer DESO127SS Stainless Steel...
    Bosch HBN 642 -- single oven cycles and doesn't get above 325
    WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
    May 28, 2008 | Ovens
    Kenmore electric oven
    Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
    Dec 02, 2007 | Ovens
    After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
    Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
    Oven not heating
    there is more to this than meets the eye if youre oven takes a long time on fan setting it may be thermostat but more likely to be fan not turning at all or quickly enough the stat capillary is above oven element and if fan not blowing air away from capillary oven stat will shut oven temp down too soon if using conventional heat eg no fan make sure there are no full size trays directly on bottom of oven this will block heat from bottom element effectively giving only half the heat output.
    hope this helps
    Jun 13, 2007 | Bosch HBN 430560B / 430520B Single Oven
    Oven will not heat?
    you have the oven on automatic in error. switch off at mains. leave for 5 mins. turn on, consult your handbook on how to set clock and having done this, bet it works
    Jun 12, 2007 | Bosch HBN 43L550B SS Electric Single Oven
    Oven heats up then switches off
    there is an overheat stat in the oven which turns it off if overheating. the causes are several. 1 - oven thermostat is faulty and oven is reachingf too high a temp. 2 - there is a second fan in the casing to keep the casing cool. 3 - this second fan is turned on by a fan start stat which may be faulty and is not starting the cooling fan 4 - the overheat stat itself is faulty. it is a bit difficult to narrow it down from afar. get back to me if you want
    May 19, 2007 | Electrolux EOB6636X Ultrafan Electric...
    Ovens Logo
    16 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
