Question about Kenmore 24032\24036 Top Load Washer
Repair manual model 110. I have a 110-82980820 washer. The dogs are broken. How do i get the agitator appart to replace the dogs? I have the agitator out of the machine already.
onthejob5130
  • 640 Answers
SOURCE: kenmore-80series washer -the agitator needs to be replaced.
remove the agitator cap,,remove the plastic seal under just pull straght up with your hand,,inside agitator theres a nut,,remove thi 1/2 inch nut with ractet and pull agitator straight up
Posted on Dec 28, 2008
jtbjtb
  • 135 Answers
SOURCE: broken washer belt
This machine has no belt. It does have a motor coupling. Easiest way to replace it is to lay the machine on its back. Remove the pump cilps and slide the pump out of the way. Remove the motor clips (they may each have a 5/16 screw), and slidt the motor out. Replace the coupling and assemble in reverse order. Coupling # 285753 available at www.timerking.com for 9.99 or from sears. Hope this helps!
Posted on Feb 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Washer making rubing noise while turning
On the back of your machine you can remove the back panel think it is about 8 screws. Once you get the back panel off look closely at the motor. Motor mounts, gears, clutch, brake, and if need be take the bottom apart and look at the main bearing on the bottom of the drum to make sure that hasnt gone bad
Posted on Feb 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: Dog Agit replacement on a Kenmore washing machine?
Take the top cap off the agitator.
Remove the plastic cover inside.(use pliers to pull it off).
Remove the bolt.
Pull the top half of the agitator off.
Replace the dogs.
Re-install the agitator.
Posted on Mar 08, 2009
  • 188 Answers
SOURCE: kenmore washer agitator
Remove the agitator cap and the bolt in the middle that holds the agitator. Reach underneath the sides of the agitator and pull up. Try gently rocking it around as you pull, I'm sure it's going to be stuck pretty tight.
Posted on Mar 12, 2009
My kitchenaid washer is not agitating normally, barely agitates and I'm looking for a manual for my model KAWE900TAL0, is there one available?
Hello.
Repair manuals are indeed available but are $15-20 and take a average of 2 weeks to arrive.However bing very experienced in all brand of the Whirlpool washer which makes the Kitchen Aid brand,i believe 1of 2 things will cause that.
Firstly if it agitates on the lower portion and its just the upper barrel of the agitator that isn't working plus it also spins the water out normally and the clothes dont come out dripping wet,its going to be the parts in the upper agitator called the dogs because they appear to look like dog paws,are wore out and not catching. I have included 2 youtube videos showing step by step how to replace the dogs and the part ill talk about in a minute. The dogs could be replaced seperatly or the kit as shown in the video,ill give you part numbers at the end of the email.
The other thing it could be espically if it doesnt agitate at all AND also doesnt spin well leaving the clothes dripping wet when removing them to the dryer.will be a broken motor coupler and i have included a video for replacing that as well
The part that it turns out to be could be purchased at your appliance parts store or on there at REPAIRCLINIC.COM or elsewhere on line at;
searspartsdirect.com
appliancepartspros
apwagner.com
midwestapplianceparts.com
http://www.youtube.com/user/RepairClinic?v=0GQh8JLqVv8&feature=pyv&ad=5457341621&kw=agitator dog replacement video
http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5457341501&kw=washing%20machine%20coupler motor coupler video
PART NUMBERS
dogs alone 80040
complete dog kit 285811
motor coupler 285753A
Good luck,i hope i have been able to help you fix your washer,
Gene
Aug 13, 2011 | KitchenAid Washing Machines
The agitator in the machine stopped working. I can spin it freely by hand in either direction
Sounds Like the agitator dogs are worn or broken. they are easy to change
  1. Remove the Fabric Softener Dispenser (#1 on diagram)
  2. Remove the Agitator Bolt. (#2 on diagram)
  3. Replace the Agitator Repair Kit
There are 3 Lengths of agitator cams
If you go to http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503228&diagram_id=28254127#d28254127
And Click on #20 on the Agitator, basket and tub Diagram
You can see pictures of the 3 lengths of cams order the one that matches your washer
Jun 25, 2011 | KitchenAid KAWS700L Top Load Washer
I need to fix the agitator on my washing machine as i it not swirling the washing during the cycle
The agitator dogs are worn and needs replacement if the motor runs and the bottom part of the agitator agitates but the top part of the agitator does not. The motor coupler or drive belt is broken if the washer fills and the motor runs but no agitation at all. The lid switch is faulty if the motor does not run at all. Please let us know which among the cases stated above the washer is in and indicate the make and exact model number for specific and accurate troubleshooting and repair advice and for the exact replacement part numbers.
May 29, 2010 | Washing Machines
Whirpool Topload Washer: Agitator
well if you grab ahold of the agitator turn it 1 way and real quick back the other way and your able to turn it back then the dog ears are wore out and is easy to replace, can get them from your nearest appliance shop or order from Repairclinic.com, you can also get a manual from them if needed!
Feb 10, 2010 | Whirlpool LBR5432L Top Load Washer
Washer won't agitate
First, see the Sears parts site for washer model # 110.22952100 which I believe is your model.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22952100+
Look at the section containing the agitator and you should see how the parts fit.
Also see the following for an illustrated description of replacing the "dogs"
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore Washing Machines
Agitator does not turn in my GE washer, it is 3 years old
Sounds like the agitator dogs have aged and broken apart. these are easy fixes at about 5.00- 10.00 and require the removal of the one bolt that holds the agitator down. After confirming this, take your washer model number and make to parts store and get replacement dogs. Hope this hepls..
Oct 27, 2009 | GE Washing Machines
Agitator doesn't agitate - kenmore model 110
how old is the machine? agitator dogs in agitators have only been used for the past 15 or so years. sounds like you need to take the agitator out and replace the 4 dogs in the top of the agitator. not a costly repair.
Oct 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Washer 70 Series - agitation problem
Check out this video if the top just spins this is your problem and directions to repair it.
http://video.google.com/videosearch?hl=en&client=opera&rls=en&hs=Rfi&q=how%20to%20change%20whirlpool%20agitator%20dogs&um=1&ie=UTF-8&sa=N&tab=wv#
Sep 06, 2009 | Kenmore 22422 Top Load Washer
Whirlpool GSQ9632LW0 problem
looks like the agitator dogs are broken. these are the pieces between the bearing and the top of the agitator. since this agitator is a 2 piece, you can just replace the dogs.
go to www.whirlpoolparts.ca and put in your model #. it will give you a parts breakdown.
hope this helps.
c
Sep 23, 2008 | Whirlpool AWM6120 Front Load Washer
Mad dog kit? Bird dog kit? Some kinda dog or somthin'?
Your model number will be located somewhere around your tub opening under the lid. The parts you are looking for are called "agitator dogs" (yes, there is such a thing). There are four of them located under the agitator cap that help grip the agitator shaft when turning. This causes the agitator to crank in one direction during the wash cycle. The part number for the entire repair kit is 2744 and costs $16.80. This includes all the washers and bushings as well as the dogs. If you just want to purchase the dogs, the part number is 3109 and costs $5.20. For a little more, the entire kit would be a better recommendation. You can get everything you need at repairclinic.com. If you cannot locate your model number, type in the brand name of your washer (i.e., Whirlpool Stylemaster Washer) in the "Search" window and you will find what you need. These parts are the same identical parts that your major appliance service companies use, but cost much less (I should know, I used to work for one of them). Let me know if you decide to repair on your own and I can give you follow-up advice on how to take the agitator apart and replace the parts you need.
Jan 22, 2008 | Whirlpool LSR6232J Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
