Question about Philips 3-Disc Changer FW320C Cassette/CD Boombox
How to clean cd lens - Philips 3-Disc Changer FW320C Cassette/CD Boombox
2000. Why doesn't it play a CD and indicates ER6?
Did you try to clean the lens of your optical reader? A typical product is selle dy Amazon and most retail stores
Memorex CD and DVD Lens Cleaning Kit
Tutorial to use a cleaner is shown in youtube
How to Clean CD DVD Laser Lens in Computer
How to clean DVD or CD player or recorder lens Sony RCD W500C
how to clean car audio player
and much more, just do a google search for
Youtube Clean Car DVD Lens
Jul 25, 2015 | Subaru Outback Cars & Trucks
How do i clean the heads
Without opening a cd player it's hard to reach the lens. You can buy lens cleaning CD's that can clean the lens a little.
Oct 25, 2014 | JVC Audio Players & Recorders
CD tray opens and shuts fine. With CD loaded and shut the screen still says NO DISK. These are disks which have always played without problem on this CD player. Is there anything I can try before taking...
When the CD player loads properly and still reads as no disk this indicates that the player lens (Optical device which reads the disk information) Is either dirty or bad. The only option you have is to get a disk lens cleaner and run it on the system. Once you run it, it is supposed to work if the lens is not spoilt. Otherwise you will just have to replace the lens by taking it to a repairer.
Hope this solution has been helpful?
Jan 17, 2011 | Audio Players & Recorders
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    Am getting code e-04 which manual says is dirty cd remove and clean ive looked at all cds and all appear speckless
    The CD lens may be dirty. If you have a CD lens cleaning kit or a CD-rom with a cd lens cleaning brush, I suggest you try either of those. Don't use a paper towel as they can be quite abrasive to a delicate CD lens. If you have camera lens cleaning equipment and can see the CD lens (use a flashlight), you may attempt to gently clean the lens with the camera lens cloth and solution.
    Aug 20, 2009 | Sony CDX-454RF 10-Disc CD Changer
    CD player does not recognize the cd's in the player
    Hi, you will need to replace the optical lens assembly asap if possible. this is basically what the issue is at Thia's time. you can confirm my diagnosis by trying to clean the lens with a lens cleaning disc. if the cleaning dosen't restore the reading ability of the lens, you will need to replace the optical lens assembly when possible.
    please rate and have a great memorial day:)
    May 25, 2009 | Sony SCD-CE595 5-Disc CD Changer
    I hav lg dvd writer it plays cd but dvd what to do
    That is because of a dirty or defective lens. When you have a lens problem the unit may still play CD but not DVDs.
    Try first using a lens cleaner disk, like the ones here.
    If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
    How to Clean the Laser Pickup Lens on your DVD Player
    How to safely clean a DVD lens?
    Clean DVD lens, or replace player?
    Clean CD or DVD ROM lens with a brush?
    Cleaning your DVD drive
    How to clean a DVD player
    Feb 15, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
    Plays cd's but lots of skipping going on. I tried cleaning with a CD player disc cleaner that I got today. That didn't help. None of the CD's skip in another machine. Thanks!!
    When optical lens got dusty or thin layer of dust on lens, cd starts skipping, as you tried cleaning with lens cleaner cd but no result.
    You need to open the unit and clean the lens with good quality cotton bud / swab with care.
    Still no joy, replace optical lens.
    Oct 10, 2008 | Sony XPLOD CDX-GT200 CD Player
    Cleaning lenses
    Hello sir,
    Buy a good and branded Cd Lens Cleaner CD and put into cd player and play it.... It will clean the CD lens properly... try it
    BEst of luck
    Cheers!!!!!!
    Jan 19, 2008 | Sony PSYC D-NF430 Personal CD Player
    Philips 3-Disc Changer FW320C Cassette/CD Boombox Logo
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
