Question about Dishwashers
Siemens se65e330gb cold water and arms do not spin
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My siemens dishwasher bottom arm does not spin to
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Feb 24, 2011
Milky water when rinsing in dishwasher & gritty covering on dishes
I have spent many years (47) in the catering industry using catering dishwashers, under counter models, corner- wash stations and also conveyer machines..
The milky water is a by-product of the wash water and rinse water mixing.
The spray are has to rotate freely or the dishes won't wash or rinse properly. They spins a lot faster than you realise and this adds pressure to the water, but also a pulsating effect to remove dirt.
Over doing the salt can cause more problems that it solves. The gritty film may indeed BE salt. I actually prefer Calgon as a softener.
My advice is to remove both top and bottom spray arms. Check the slots/holes for obstruction, and run water through them under a tap, outside to inside (the opposite to how it is in the machine) rocking the arms up and down to allow any obstructions to flush out. Lemon pips and toothpicks are out biggest problem! Put the arms back and make sure they spin freely. Sometimes they just lock up for no apparent reason!
Use CLR descaler in the machine to clean it using the instructions on the bottle. Then run the dishwasher using the recommended doses of detergent and rinse aid.
Jan 19, 2016 | Siemens Dishwashers
Rinse arms have been thoroughly cleaned ,replaced and spin very freely , but will not spin resulting in poor washing results, could it be pump ?
if said pump suppliesthe water to the spray arm of course it cold be . just like lawn sprinklers the more pressure the faster then spray goes round and round
Mar 29, 2015 | Dishwashers
Siemens Dishwasher Fault
there is a water level sensor in the bottom of the machine if this is faulty and stays on, this will indicate to the pump there is water still in the machine. I would check this sensor it might be blocked with debris and has blocked in the closed position. that woudl be the best start for this issue.
i hope this was useful.
Feb 15, 2013 | Dishwashers
The dishwasher arm on the top is not spinning so the dishes are not getting clean.
The arms on a dishwasher spin with water pressure remove your arm and thouroughly clean and flush through , also check for wear on the arm bushes to see if there is excessive wear , the washers may need to be changed. Check the supply hole to the top arm to make sure it is not blocked.
Feb 07, 2013 | Siemens 24 in. SL84A305UC Built-in...
My siemens dishwasher bottom arm does not spin to clean the bottom basket of dishes. Everytthing else works fine. I have removed and cleaned out all washing arms and plastic water carrier inside...
Dishwasher
How to Buy
heatman101
Feb 23, 2011 | Siemens 24 in. SE64A630GB Built-In...
My siemens WD1252 doesn't change from wash to rinse
Hallo,
I have the same problem since yesterday. I've seen that probably it doesn't warm up the water. If I change washing temperature to "cold" everything works normally. I think that heater is broken.
Have You resolved your problem? Have You called service?
Best regards.
Bartosz
May 01, 2010 | Siemens WDi1640 Front Load Washer / Dryer
The upper arm is not rotating
Take it apart and clean it, water pressure should spin it around, there are bits of food/rice plugging it and stoping it from rotating.
Apr 22, 2010 | Siemens SE24A230 ExtraKlasse Built-In...
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
My siemens washing machine does not spin but the water in and out functions are normal
Hi, I have a Siemens WXL166AGB washing machine that has started jolting violently when on the spin cycle, as if something is out of balance, never getting fully up to speed. Subequently it cuts short the spin cycle and leaves the clothes wet. Any idea what it could be. Thank you, Phil Vanes
Nov 08, 2009 | Siemens WD61392GB Front Load Washer /...
Lower Spray Arm doesn't Rotate on Siemens SE55A560 Dishwater
upper and lower connection should be same type of setup
missing part thus?
This sometimes is also caused by not driving in right the rack (closing properly) mating the connections tight. My old Bauknecht had this little problem.
Unfortunately I have no manual with parts drawings.
Still warranty?
Parts shop nearby?
Upper connection does have rubber ring or is a conical seal?
And when you fill the basket, no teaspones or such dropping too far down? My error many times.........
Apr 14, 2009 | Siemens Dishwashers
Dishwashers Logo
19 people viewed this question
Top Dishwashers Experts
Owen Barnes
