Question about Whirlpool Refrigerators
WHIRLPOOL REFRIGERATOR G15SVAXVQ01 BOTTOM FREEZER LIGHT WILL NOT GO ON
  • 1122 Answers
SOURCE: WHIRLPOOL BOTTOM FREEZER / DEFROST
why do you want to defrost your freezer?is it not frost free?if so you have a defrost problem,but if you want you can unplugg it and use a hair dryer to defrost it,let me know how you do-mike
Posted on Oct 30, 2008
  • 12 Answers
SOURCE: My whirlpool refrigerator (8 years old) is not cold and hums
Possible of 3 reasons.
1) Defrost bimetal is open and not allowing power to heater element in evaporator coil in freezer.
2) Defrost timer is not going into defrost, motor stopped moving.
3) Evaprator fan motor is not rotating. Possible motor.
First check for frost in the back panel of the freezer section.
if there is frost and the fan is operating, would suggest manually putting unit into defrost, depending on particular model. may be a switch you can move with a standard screw driver to get the fans and compressor to shut off. If you find this either. Top of fridge in refrigerator section below temperature selection controls. Or remove toe plate, the pretty decor under the door. and it will be in there.
If this is an electronic style, look under that toe kick and there is a technician's sheet that will explain how to get into defrost.
Allow 10 minutes for heater to heat, listen for water sizzling on heater element. if this does work. you will need the defrost timer.
Hope this helps.
Posted on May 14, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
  • 57 Answers
SOURCE: The Whirlpool Gold refrigerator is not cooling and
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
Posted on May 26, 2011
richroth
  • 9472 Answers
SOURCE: In the refrigerator section, the freezer and
The control board that is on the back outside panel of the refrigerator needs to be replaced. Unplug the refrigerator and remove the protective cover that you will find over that control board. Document the locations of the wiring connections or take a digital picture of the control board before removing any wires so that they can be reconnected properly. Remove all of the wiring connections and replace that control board. Reconnect the wires and reassemble the refrigerator.
Here is a link to the part you need.
Posted on Jul 29, 2011
How do I fix the freezer light in my Whirlpool side-by-side/freezer on bottom fridge?
first make sure the light bulb works for sure. then most likely it is the door switch. easy to replace. pull out, disconnect and replace. while you are at it, touch the two wires together and make sure the light goes on so you know it is the switch.
Aug 09, 2015 | Whirlpool Refrigerators
My whirlpool refrigerator is not cooling but my bottom freezer is fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 11, 2011 | Whirlpool GX5FHTXT Bottom Freezer French...
Whirlpool gold refrigerator is not cooling ice build up in freezer. Water on bottom of refrigerator.
Too much build of ice in freezer will not cooled the refrigerator side, you need to defrost the fridge. Set it to proper temp setting, just enough to have ice on the freezer and also remove water on the bottom.
Thanks for asking.
Jun 24, 2011 | Whirlpool Refrigerators
Ice build up on freezer door
your door gasket isnt set right call for warranty service
Jun 03, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
Top freezer of whirlpool frosting up bottom notgetting cold
If your fan motor is blowing then I would say you have a defrost problem. How about a good old apartment top mount ice box manual from whirlypool?
TOP MOUNT REFRIGERATORS
Nov 06, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
Refrigerator Not Cold
You are not moving air between the freezer and refrigerator sections. This may be due to a defective fan motor or a frozen evaporator coil.
Aug 09, 2009 | Whirlpool ET4WSKXS Top Freezer...
Water in the bottom of the refrigerator
you have to take out the back postion in side the freezer please ulplug the refrigerator under the evaparator is the drain throw hot water in there
Mar 30, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool ET1MTMXKQ01
is you compressor running? do you have heat in condensor check your the evaporator for a frost pattern..
let me know if you need help
Apr 04, 2008 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
